10 Tips for Maintaining Your Compact Track Loader
June 11, 2023
A compact track loader (CTL) is a versatile machine that can be used for a variety of tasks, including loading, digging, and transporting materials. It is also relatively easy to maintain, which can help to extend its lifespan and keep it running smoothly.
Regular maintenance is essential for keeping your CTL in top condition. By following the tips in this article, you can help to ensure that your machine operates at peak performance for years to come.
Here are the top 10 maintenance tips which make your compact track loader long-lasting. If you follow these tips it will reduce your cost of maintenance.
Choosing the Right Compact Track Loader
Many great companies make loaders, so it depends on what you're looking for in a machine. Here are a few of the top brands:
Caterpillar: Caterpillar is a well-known and respected manufacturer of construction equipment. Their leaders are known for their durability and performance.
John Deere: John Deere is another major player in the construction equipment industry. Their leaders are known for their comfort and operator-friendliness.
Komatsu: Komatsu is a Japanese company that makes a wide variety of construction equipment. Their leaders are known for their fuel efficiency and ease of maintenance.
Case: Case is an American company that makes a variety of construction equipment, including loaders. Their leaders are known for their versatility and affordability.
Tip 1: Regularly inspect and clean the undercarriage components
The undercarriage of your skid steer loader is the part that comes in contact with the ground, so it's important to inspect it regularly for any signs of wear or damage. This includes checking the tracks, rollers, and tires. If you see any problems, be sure to repair them right away to prevent further damage. Here are some tips for inspecting and cleaning the undercarriage of your skid steer loader:
  1. Inspect the tracks: Check for cracks, tears, or missing links. If you see any problems, be sure to replace the damaged parts.
  2. Inspect the rollers: Check for wear and tear. If the rollers are worn, they will not be able to support the weight of the machine, which can lead to damage to the tracks and other components.
  3. Inspect the tires: Check for wear and tear, and make sure the tires are properly inflated. Underinflated tires can cause the machine to wobble, which can lead to damage to the undercarriage and other components.
  4. Clean the undercarriage: Use a pressure washer to clean the undercarriage of dirt, debris, and mud. This will help to prevent wear and tear on the components, and it will also help to extend the life of your machine.
Tip 2: Check and replace track components as needed
The tracks on your skid steer loader are what keep it moving, so it's important to keep them in good condition. Check the tracks regularly for any signs of wear and damage, such as cracks, tears, or missing links. If you see any problems, be sure to replace the damaged parts right away. Here are some tips for checking and replacing track components:
  1. Check the track tension: The track tension should be adjusted according to the manufacturer's recommendations. If the track tension is too loose, the tracks can come off, and if the track tension is too tight, the tracks can wear out prematurely.
  2. Check for cracks and tears: Check the tracks for cracks and tears. If you see any cracks or tears, be sure to replace the track immediately.
  3. Check for missing links: Check the tracks for missing links. If you see any missing links, be sure to replace the track immediately.
Tip 3: Properly lubricate all moving parts
Lubrication is essential for keeping your skid steer loader running smoothly. Be sure to lubricate all moving parts according to the manufacturer's recommendations. This will help to prevent wear and tear on the parts, and it will also help to extend the life of your machine.
Here are some tips for lubricating all moving parts:
  1. Use the correct type of lubricant: Be sure to use the correct type of lubricant for the specific type of moving part. For example, you should use a high-pressure lubricant for the hydraulic system, and you should use grease for the gears and bearings.
  2. Lubricate all moving parts regularly: Be sure to lubricate all moving parts according to the manufacturer's recommendations.
  3. Apply the lubricant evenly: When applying lubricant, be sure to apply it evenly to all surfaces of the moving part. This will help to ensure that the lubricant is evenly distributed and that it will not get washed away by dirt and debris.
Tip 4: Keep the hydraulic system in optimal condition
The hydraulic system is what powers the various functions of your skid steer loader, so it's important to keep it in good condition. Be sure to check the hydraulic fluid level regularly, and add fluid as needed. You should also have the hydraulic system flushed and serviced at regular intervals.
  1. Check the hydraulic fluid level regularly.
  2. Has the hydraulic system been flushed and serviced at regular intervals?
  3. Check for leaks.
  4. Inspect the hoses.
  5. Use the correct type of hydraulic fluid.
Tip 5: Maintain clean fuel and air filters
Clogged fuel filters can restrict fuel flow, which can lead to poor performance and even engine damage. A clogged air filter can restrict air flow, which can lead to poor engine performance and even engine damage. Be sure to check and replace the fuel and air filters according to the manufacturer's recommendations.
  1. Check the fuel filter regularly.
  2. Replace the air filter according to the manufacturer's recommendations.
Tip 6: Follow recommended oil change intervals
The oil in your skid steer loader's engine helps to keep it running smoothly and prevent wear and tear on the parts. Be sure to change the oil according to the manufacturer's recommendations. Changing the oil at regular intervals will help to extend the life of your engine.
  1. Use the correct type of oil.
  2. Change the oil regularly.
  3. Dispose of the old oil properly.
Tip 7: Inspect and maintain electrical and battery systems
The electrical and battery systems are essential for keeping your skid steer loader running. Be sure to inspect the electrical system regularly for any signs of damage, such as loose wires or corroded connectors. You should also have the battery tested at regular intervals to ensure that it is in good condition.
  1. Inspect the electrical system regularly.
  2. Have the battery tested at regular intervals.
  3. Keep the battery clean and dry.
Tip 8: Clean and protect the cab and controls
The cab and controls on your skid steer loader are where you spend most of your time, so it's important to keep them clean and protected. Be sure to clean the cab regularly to remove dirt, dust, and debris. You should also apply a protective coating to the cab and controls to help prevent them from fading or cracking.
  1. Clean the cab regularly.
  2. Apply a protective coating to the cab and controls.
Tip 9: Check and adjust the tension on belts and hoses
Belts and hoses are essential for transferring power throughout your skid steer loader. Be sure to check the tension on the belts and hoses regularly to ensure that they are properly adjusted. Loose belts and hoses can cause damage to the engine and other components.
  1. Check the tension on the belts and hoses regularly.
  2. Adjust the tension on the belts and hoses as needed.
  3. Replace any damaged belts or hoses immediately.
Tip 10: Regularly inspect and maintain attachments
If you use attachments with your skid steer loader, be sure to inspect and maintain them regularly. This includes checking for any signs of wear or damage and lubricating the moving parts. Regular maintenance will help to extend the life of your attachments.
  1. Inspect the attachments regularly for any signs of wear or damage.
  2. Lubricate the moving parts of the attachments as needed.
  3. Replace any damaged attachments immediately.
Regular maintenance is vital for the optimal performance and longevity of your compact track loader (CTL). By following the ten maintenance tips provided in this article, you can reduce maintenance costs and ensure your CTL operates at its best. These tips cover various aspects, including inspecting and cleaning undercarriage components, lubricating moving parts, maintaining the hydraulic system, and cleaning fuel and air filters.
Additionally, maintaining the electrical and battery systems, cleaning the cab and controls, and inspecting attachments are crucial. By implementing these practices and addressing issues promptly, you'll enhance performance, reliability, and lifespan, making your CTL a valuable asset for your tasks and projects.
