3 Min read
July 2, 2024
Cutting through concrete, whether for a renovation, installation of windows, or other construction tasks, requires the right tools to ensure precision, safety, and efficiency. Here are the best concrete saws that professionals recommend for various applications.
Overview: The Husqvarna K770 is a versatile and powerful handheld concrete saw known for its reliability and cutting efficiency. It is suitable for both wet and dry cutting.
Blade Size: 14 inches
Cutting Depth: Up to 5 inches
Engine: 74cc two-stroke
Weight: 22 pounds
SmartTension: Ensures optimal power transmission and minimum wear.
Powerful and efficient for a variety of concrete cutting tasks.
Lightweight design for better maneuverability.
Durable construction with minimal maintenance needs.
May require two passes for thicker concrete (over 5 inches).
Higher price point but offers great value for durability.
Overview: Stihl is a renowned brand in power tools, and the TS 800 Cutquik is designed for heavy-duty concrete cutting. It is ideal for professional contractors needing robust performance.
Blade Size: 16 inches
Cutting Depth: Up to 6 inches
Engine: 98.5cc two-stroke
Weight: 28 pounds
Elastostart: Reduces startup shock for easier handling.
Powerful engine for cutting through thick concrete.
Designed for heavy-duty applications with durable components.
Effective anti-vibration system for reduced operator fatigue.
Heavier than other models, which might be tiring for prolonged use.
Higher fuel consumption due to the powerful engine.
Overview: The Makita EK7651H stands out with its 4-stroke engine, providing a more efficient and quieter operation compared to 2-stroke engines.
Engine: 76cc 4-stroke
Weight: 28 pounds
Automatic Decompression Valve: Ensures easy starting.
Lower emissions and quieter operation due to the 4-stroke engine.
No need for mixed fuel, simplifying maintenance.
Reliable performance with reduced vibration.
Heavier compared to some 2-stroke models.
Slightly more complex maintenance requirements for a 4-stroke engine.
Overview: For those requiring deeper cuts, the Husqvarna K970 Chain Saw offers unique capabilities with its chain design, allowing it to cut deeper and more intricate shapes.
Cutting Depth: Up to 15 inches
Engine: 94cc two-stroke
Weight: 22.4 pounds
X-Torq Engine: Reduces emissions and fuel consumption.
Superior cutting depth for thicker concrete slabs.
Ideal for cutting openings, irregular shapes, and deeper cuts.
Efficient fuel consumption with low emissions.
Requires specific maintenance for the chain.
Higher initial investment.
Overview: For extensive concrete cutting projects, the Wacker Neuson BFS 1345 walk-behind saw offers the stability and power needed for large-scale tasks.
Blade Size: 18 inches
Cutting Depth: Up to 7.5 inches
Engine: Honda GX390
Weight: 219 pounds
Vibration Dampening: Ensures smoother operation.
Ideal for large concrete cutting projects with deep cutting needs.
Stable and powerful with a robust engine.
Easy to operate with a focus on user comfort.
Not suitable for small or indoor projects due to its size.
Requires significant storage space and maintenance.
Selecting the right concrete saw depends on the specific needs of your project, including the thickness of the concrete, the required cutting depth, and the volume of work. For general use, the Husqvarna K770 and the Stihl TS 800 are excellent choices, offering a balance of power and maneuverability. For deeper and more specialized cuts, the Husqvarna K970 Chain Saw and the Wacker Neuson BFS 1345 provide the necessary capabilities. Investing in a high-quality concrete saw will ensure efficiency and longevity, making your construction projects smoother and more professional.
