Best Wheel Bearing Grease
3 Min read
October 29, 2024
Here's a list of the best wheel bearing greases, with Lucas 10005 Red 'N' Tacky as the top recommendation based on its performance, reliability, and user reviews.
1. Lucas 10005 Multi-Purpose Red 'N' Tacky EP Grease
Lucas Red 'N' Tacky takes the top spot for good reason. This grease is praised for its ability to handle high pressure and temperature while maintaining a tacky consistency, which makes it ideal for wheel bearings in both standard and heavy-duty applications. With a high drop point and water-resistant properties, it offers excellent longevity and protection against wear and corrosion.
  1. Best for: High-pressure applications, heavy-duty use, general-purpose lubrication
  2. Price: Around $6.98 (14 oz)
  3. Why It’s #1: The tackiness ensures it stays in place, providing consistent lubrication under various conditions.
2. Timken GR224TUB Automotive Wheel Bearing Grease
Timken GR224TUB is a top performer known for its durability and high-temperature resilience, which makes it especially suited for automotive wheel bearings. This grease boasts an impressive drop point, providing a long-lasting solution for high-stress applications.
  1. Best for: Automotive applications, high-temp resilience
  2. Price: Around $13.76 (14 oz)
  3. Why It’s a Top Pick: Its durability under high stress makes it ideal for heavy vehicles or off-road use.
3. Valvoline Multi-Purpose Grease VV614
Valvoline's Multi-Purpose Grease is an affordable, high-temperature option that's great for various applications, from automotive bearings to general lubrication. It provides reliable protection against wear and corrosion, making it a go-to for those needing a versatile grease that works under extreme conditions.
  1. Best for: Versatile applications, budget-friendly option
  2. Price: Around $6.89 (1 lb)
  3. Why It’s Great: The affordability and versatility make it perfect for routine maintenance across different vehicles and machinery.
4. CRC SL3111 Wheel Bearing Grease
CRC SL3111 is formulated specifically for wheel bearings, with a high-temperature tolerance and superior rust protection. It’s lithium-based, meaning it offers excellent stability and won’t break down under high load or heat.
  1. Best for: Extreme pressure environments, rust protection
  2. Price: Around $11.89 (14 oz)
  3. Why It’s Reliable: This grease holds up well in high-temperature applications, offering strong protection against rust and corrosion.
5. Atomlube Ultra Heavy Duty Red Grease
For those needing industrial-strength protection, Atomlube’s Ultra Heavy Duty Red Grease delivers. It’s a premium option that resists extreme temperatures and pressures, ideal for those in harsher climates or heavy-duty applications.
  1. Best for: Industrial and heavy-duty applications
  2. Price: Around $22.79 (14 oz)
  3. Why It’s Worth the Investment: This heavy-duty grease withstands extreme conditions, offering premium protection in challenging environments.
For everyday and heavy-duty use, Lucas Red 'N' Tacky leads the pack with its high-performance, tacky formula. If you’re looking for affordability, Valvoline’s option is an excellent choice, while Timken and CRC SL3111 offer specialized, high-temp durability for automotive applications. Atomlube is a premium choice for heavy-duty needs, rounding out the list as a robust option for the toughest jobs.
