What is a Crane Boom and How Does it Work?
9 Min read
May 3, 2024
The term "crane boom" refers to the extendable or fixed arm of a crane, which is a pivotal piece of equipment used in lifting heavy loads. The boom is typically the most recognizable part of the crane and is responsible for the direct support and movement of the load, this is lead by crane hand signals.
Cranes come in various types, each designed for specific tasks and environments. Here are the main types of cranes, focusing on differences in their booms and general utility:
1. Telescopic Crane
Telescopic cranes feature a boom that consists of several tubes fitted within each other, which can extend or retract to adjust the boom's length. This capability allows the crane to achieve a versatile range of heights and lengths, making it highly adaptable for different operational needs.
Usage: Telescopic cranes are particularly valuable in scenarios that require both mobility and flexible reach, such as rescue operations and tasks in confined spaces where precision and adaptability are critical. They are commonly utilized in situations where the crane needs to be moved frequently between jobs, offering quick setup and breakdown.
2. Tower Crane
Tower cranes have a prominent vertical mast and a fixed horizontal boom that is attached to a rotating upper mast section. This design allows the crane to provide a significant height and reach, which is essential for the vertical construction of tall buildings.
Usage: These cranes are indispensable in the high-rise construction sector because they offer the optimal combination of lifting capability and height. Their ability to reach high elevations and support substantial loads makes them a fundamental piece of equipment on any major skyscraper or large structure project.
3. Truck Mounted Crane
A truck-mounted crane combines the capabilities of a telescopic boom with the mobility of a rubber tire truck chassis. This integration provides excellent versatility and mobility, allowing the crane to travel on public roads and at job sites with ease.
Usage: These cranes are ideal for projects that require a crane to perform lifts at multiple locations in a single day, such as light construction, maintenance work, or when delivering materials across various sites. Their quick deployment and ability to maneuver in tight spaces make them especially useful in urban environments.
4. Rough Terrain Crane
Rough terrain cranes are equipped with a telescopic boom and are specifically designed for operations in challenging ground conditions. They typically feature rugged undercarriages and large tires, which enhance their stability and mobility on uneven surfaces.
Usage: These cranes excel in off-road and rugged environments, commonly used in large outdoor projects such as pipeline construction, large-scale earthmoving, and anywhere requiring high mobility over rough terrain.
5. Crawler Crane
Crawler cranes are equipped with a lattice boom mounted on an undercarriage fitted with a set of tracks (crawlers) instead of tires. This track system provides excellent stability and mobility over soft ground, allowing the crane to operate on less stable surfaces without extensive setup.
Usage: Ideal for heavy lifting tasks on soft or uneven grounds, crawler cranes are frequently seen in long-term construction projects like bridge building, port development, and other major infrastructural projects where stability and heavy lifting capacity are required.
6. Lattice Boom Crane
Lattice boom cranes consist of a boom made from several sections of steel or similar materials that can be extended with additional sections to reach desired lengths and heights.
Usage: These cranes are typically used for heavy lifting and high-reach tasks in environments like shipyards, heavy construction sites, and industrial projects where extensive vertical and horizontal reach is necessary.
7. Loader Crane
Loader cranes feature a knuckle boom design that allows them to be folded into a compact size. This type of crane is usually mounted on the back of a truck and is used for loading and unloading materials.
Usage: Frequently employed in logistics and delivery industries, loader cranes are pivotal in the transport of goods. They are especially useful in tight urban settings where space is limited but loading flexibility is required.
8. Overhead Crane
Overhead cranes, or bridge cranes, consist of a hoist fixed on a trolley, which moves across one or more beams at elevated levels in a facility. This design allows the crane to move loads along a fixed path within an industrial setting.
Usage: These cranes are a staple in manufacturing and assembly industries, where they are used to move heavy or bulky goods across a workshop or warehouse floor efficiently. They are crucial for maintaining productivity in industrial environments.
9. Floating Crane
Floating cranes are heavy-duty cranes mounted on pontoons or specialized vessels, designed for maritime and offshore construction, salvage operations, and for loading or unloading ships.
Usage: They play a critical role in offshore construction projects, port logistics, and in situations where traditional cranes cannot be used, such as in ship salvage operations or during the construction of marine infrastructure.
10. Railroad Crane
Railroad cranes are similar to truck-mounted cranes but are designed to operate on rail tracks. They can be equipped with telescopic or lattice booms based on their specific requirements.
Usage: These cranes are essential for maintaining and constructing railroad infrastructure. They are used for tasks such as laying new track sections, performing maintenance on existing tracks, and loading or unloading materials needed for rail operations.
Cranes or Boom Trucks?
When faced with a decision between employing cranes and boom trucks for a construction project or operational need, several critical aspects must be taken into account. The choice largely depends on factors such as the project's scale, the environment, and specific operational requirements. Below is a detailed exploration of these key considerations to help you determine the most suitable equipment for your needs:
Important Parts of a Crane
Cranes are intricate pieces of machinery, pivotal for numerous construction, manufacturing, and transport applications. Each component of a crane plays a crucial role in its operation and functionality. Here’s a detailed overview of the major components that are critical to crane operations, apart from the boom:
1. Base and Support Structure
Outriggers: These are crucial for the stability of mobile cranes. Outriggers extend laterally from the base of the crane, significantly widening its footprint. This extension helps distribute the load more evenly, which is essential to prevent tipping during lifting operations.
Undercarriage: The undercarriage is the foundational component that provides both support and mobility for crawler cranes and other mobile crane types. It typically includes tracks or wheels, which allow the crane to move around the site.
2. Hoist and Hook
Hoist: This is a key motorized component responsible for the vertical movement of the load. It operates through a system of wire ropes or chains and is powered by electric or hydraulic motors, lifting and lowering the load with precision.
Hook: The hook is attached to the end of the hoist rope and is the direct contact point for the load. It must be robust and reliable, as it handles the direct weight and stresses of the loads being lifted.
3. Wire Rope
Wire rope is an indispensable component in crane operations, comprised of multiple steel wires that are helically wound into strands. This construction allows for a combination of strength, flexibility, and durability, which are essential for the dynamic stresses of lifting heavy loads. It is used in the hoist mechanism to lift and lower loads, transmitting the force from the hoist motor effectively. Regular maintenance and inspection of the wire rope are crucial due to its constant exposure to high stress, and these checks include looking for wear such as corrosion, broken strands, or kinking. Properly selected and maintained wire rope is critical for safe crane operations, as using damaged or inadequate wire rope can significantly increase the risk of accidents. The correct type and size of wire rope, suited to specific lifting tasks and environmental conditions, ensure the crane operates safely and efficiently.
4. Counterweights
Counterweights are strategically placed at the rear of the crane to balance the load weight. This balancing act is crucial to maintain the crane’s stability and prevent it from tipping over during lifting operations. The amount and placement of counterweights are carefully calculated based on the crane’s maximum load capacity and boom length.
5. Rotex Gear
The Rotex gear, or slewing unit, is a pivotal component situated between the crane's upper and lower structures. It enables the entire upper part of the crane, including the boom and the load, to rotate around a vertical axis. This rotation capability is essential for the crane to perform lifts and movements in all directions without needing to reposition the entire machine.
6. Operator’s Cab
Located typically above the base, the operator's cab is the control center where the crane operator manages the crane’s movements. It is equipped with multiple controls, displays, and sometimes advanced safety systems to assist in precise and safe operations. The cab is designed to provide a good vantage point while protecting the operator from environmental elements and operational hazards.
7. Jib
The jib is an additional extension of the crane boom that provides greater reach and flexibility. It is often used to extend the operational capacity of the crane beyond the main boom's length, allowing it to lift loads to higher elevations or reach across obstacles on the ground.
8. Pulleys and Sheaves
Pulleys and sheaves are wheel-like components with grooved rims that guide and change the direction of the wire rope used in the crane's lifting mechanism. They are crucial in the mechanical advantage system that allows the crane to lift loads heavier than the hoist could support directly.
9. Safety Systems
Load Moment Indicator (LMI): This safety system provides the operator with real-time data on the load’s weight and its distribution relative to the crane's operational capabilities. It helps prevent overload situations that could lead to accidents.
Anti-Two Block Device: Installed to prevent accidents that occur when the hook block collides with the boom tip, this device stops the hoist when the hook block approaches too close to the boom tip, thereby preventing potential damage or failure.
10. Power Plant
The power plant is the engine that powers the crane’s operations, which may be an electric motor or an internal combustion engine. In mobile cranes, this engine is often distinct from the vehicle’s engine, designed specifically to supply power for lifting and moving loads.
