9 Min read
September 9, 2023
Articulated trucks are essential heavy equipment vehicles used in various industries for transporting materials, debris, and heavy loads. These trucks are a crucial part of construction, mining, and other earth-moving operations due to their unique design and capabilities.
In this article, we will discuss the essential features of articulated trucks, their different types and applications, and the benefits and operating costs of using them. We will also provide tips for maintaining your articulated truck to ensure its safety, efficiency, and longevity.
Articulated rigid dump trucks, also known as articulated haulers or dump trucks, are essential heavy equipment vehicles used in various industries for transporting materials, debris, and heavy loads. These trucks are a crucial part of construction, mining, and other earth-moving operations due to their unique design and capabilities.
An articulated truck consists of two main components: the tractor unit and the dump body. The tractor unit contains the engine, transmission, cab, and front wheels, while the dump body is a trailer-like structure attached to the tractor unit with a pivot point, allowing it to articulate or bend in the middle. This articulation provides increased maneuverability, especially in challenging terrains, making articulated trucks indispensable in demanding work environments.
Articulated trucks come in various types and sizes, each designed to serve specific purposes. The Komatsu traction control system in the articulated truck bare chassis with manual transmissions helps to ensure safe operation by tire pressure monitoring. Here are some of the most common types:
Articulated dump trucks, often referred to as ADTs, are the most recognizable and widely used type of articulated truck. These trucks are designed for off-road applications, such as construction sites and mining operations. They feature large, robust tires, high ground clearance, and an articulated chassis that allows them to navigate rough terrain with ease. Articulated dump trucks are known for their impressive load-carrying capacity and the ability to dump their cargo quickly.
Bell is a well-known manufacturer of articulated trucks, offering a range of models designed for various industries. Bell articulated trucks are favored for their durability, off-road capabilities, and innovative features. They are commonly used in construction, quarrying, and mining operations, where their reliability is crucial.
Volvo is another reputable manufacturer of articulated trucks, known for producing high-quality and efficient machines. Volvo articulated trucks are recognized for their fuel efficiency, operator comfort, and advanced suspension technology. They are commonly used in construction and mining applications, where their performance and reliability are highly valued.
Terex is a global manufacturer of heavy equipment, including articulated trucks. Terex articulated trucks are known for their versatility and durability. They are suitable for a wide range of applications, from construction to forestry. Terex trucks are designed to handle heavy loads and challenging terrains with ease.
Articulated trucks are considered essential in various industries for several reasons:
One of the primary reasons articulated trucks are essential is their exceptional off-road capabilities. These trucks can navigate through rugged, uneven, and challenging terrains where traditional vehicles would struggle to operate. This makes them indispensable in construction, mining, and forestry, where the terrain is often unpredictable.
Articulated trucks are designed to carry heavy loads efficiently. Their large dump bodies can handle substantial amounts of material, which is essential for tasks like hauling ore, rocks, sand, gravel, and debris. The high load capacity and torque of articulated trucks significantly improve productivity on job sites.
Articulated trucks are highly maneuverable, thanks to their large tires and unique articulated frame design. The ability to pivot at the midpoint allows these trucks to make tight turns and navigate through narrow spaces. This maneuverability is especially valuable in congested construction sites and confined areas.
Articulated trucks distribute their weight evenly over a large surface area due to their multiple axles and wide tires. This reduces ground pressure, minimizing damage to the terrain and improving stability. It's particularly beneficial in environmentally sensitive areas and soft soil conditions.
The combination of high load capacity, off-road capabilities onboard payload weighing, and maneuverability contributes to increased productivity and efficiency on job sites. Articulated trucks can transport materials quickly and safely, reducing downtime and operational costs.
Using articulated trucks in various industries provides numerous benefits, contributing to the success of projects and operations. Here are some key advantages:
Articulated trucks can transport large quantities of material in a single trip, reducing the number of trips required to complete a task. This leads to improved productivity and faster project completion. In industries like mining and construction, and other materials where time is of the essence, this efficiency is invaluable.
Articulated trucks are known for their fuel efficiency and reduced operational costs. Their ability to carry more material per trip means lower fuel consumption and decreased labor expenses for top manufacturers. Additionally, the reduced wear and tear on the terrain translates into lower maintenance costs in the long run for manufacturers.
The versatility of articulated trucks means they can perform various tasks with the right attachments. This eliminates the need for multiple specialized vehicles on the job site, reducing equipment costs and simplifying logistics on job sites.
Purchasing an articulated truck offers long-term benefits for businesses with ongoing construction projects, or consistent hauling needs. When buying an articulated truck, consider factors such as the truck's load capacity, off-road capabilities, fuel efficiency, and maintenance requirements. It's essential to choose a reputable dealer or manufacturer to ensure you get a reliable and durable machine.
Renting articulated trucks can be a cost-effective solution for short-term projects or when you need additional equipment to meet peak demand. Renting allows you to access the latest models without the upfront capital investment. When renting an articulated truck, be sure to inquire about rental terms, maintenance, and insurance options to make an informed decision.
Articulated trucks play a vital role in the construction industry by transporting materials such as gravel, sand, and construction debris. Their ability to navigate construction sites and deliver materials precisely where needed contributes to project efficiency.
In mining operations, articulated trucks are used to haul ore, rocks, and overburden materials. The rugged design of these trucks allows them to operate underground conditions in challenging mining environments, including steep inclines and uneven terrain.
Forestry companies use articulated trucks to transport logs and timber from remote forest locations to processing facilities. Their off-road vehicle capabilities are essential for accessing wooded areas that may lack proper roads.
Quarrying operations involve extracting rocks and aggregates for construction and industrial use. Articulated dump trucks are ideal for hauling heavy loads of quarried materials.
Articulated trucks are used in agriculture for tasks such as hauling material transporting crops, soil, and feed. They can also be equipped with water tanks for irrigation purposes.
Municipalities and waste management companies use articulated trucks for collecting and transporting solid waste and recyclables. Their large capacity, power, and maneuverability make them suitable for urban waste collection.
Articulated trucks are essential for infrastructure development projects, including road construction, bridge construction, and tunneling. They facilitate the transportation of construction materials loading tools and equipment to remote and challenging locations.
Maintaining your articulated truck is crucial to ensure its safety, efficiency, and longevity. Begin by establishing a regular maintenance schedule, adhering to the manufacturer's guidelines. Before each use, perform daily inspections, checking for any visible damage, ensuring proper fluid levels, inspecting tire conditions, and verifying the functionality of safety features such as lights and brakes.
Proper lubrication is essential; ensure that all moving parts and pivot points receive the recommended lubricants at specified intervals. Keep a close eye on your truck's tires, monitoring tire pressure, checking for wear and damage, and rotating them as needed to maintain even wear patterns.
Brake maintenance is paramount for safety. Regularly inspect brake pads, discs, and the hydraulic system, addressing any issues promptly. Don't forget to examine the electrical system, including lights, wiring, and batteries, to ensure they are functioning correctly.
Hydraulic systems are common in most articulated trucks now; regularly check hydraulic hoses for leaks, damage, or wear and maintain proper fluid levels. Maintain cleanliness by regularly cleaning both the truck's exterior and interior. Cleanliness not only improves the truck's appearance but also prevents corrosion and reduces component wear.
In conclusion, articulated trucks are essential heavy equipment vehicles that play a vital role in a variety of industries. They are characterized by their unique design and capabilities, which allow them to navigate challenging terrains and carry heavy loads with ease.
The benefits of using articulated trucks are numerous, including enhanced payload capacity and productivity, cost savings, environmental considerations, and versatility. When choosing an articulated truck, it is important to consider the specific needs of your application.
By following the tips in this article, you can ensure that your articulated truck is properly maintained and operated, maximizing its lifespan, fuel costs, and productivity.
