Everything You Need to Know About Compactors: Types, Uses & Buying Guide
8 Min read
everything-you-need-to-know-about-compactors-a-comprehensive-guide-featured-image.jpg
Javier Bocanegra
Javier Bocanegra
May 30, 2023
Compactors are essential heavy equipment for construction, paving, roadwork, earthmoving, and landfill operations. By applying static pressure, vibration, kneading action, or a combination of these forces, compactors increase material density and create a more stable surface.
Proper compaction helps reduce settlement, improve load-bearing capacity, and create durable foundations, roads, parking areas, embankments, and other finished surfaces.
But not every compactor is designed for the same material or application. A smooth-drum roller may be appropriate for granular soil and asphalt, while a padfoot roller is better suited to cohesive or semi-cohesive soils. Smaller jobs may call for a vibratory plate compactor or trench roller instead.
This guide explains the major types of compactors, what they are used for, how to choose the right machine, and what to inspect when buying a used compactor.
What Is a Compactor?
A compactor is a machine that increases the density of soil, aggregate, asphalt, waste, or other materials by reducing air voids and rearranging particles.
In construction, compaction is particularly important because improperly compacted soil can settle or shift after a structure, road, or pavement is built.
Heavy equipment manufacturers offer several compactor configurations, including vibratory soil compactors, tandem vibratory rollers, pneumatic rollers, soil compactors, and landfill compactors.
The machine you need depends on the material being compacted, the required density, jobsite conditions, available space, and the size of the project.
How Does a Compactor Work?
Compactors use different forms of mechanical force to increase material density.
Static pressure uses the machine's weight to compress the material underneath the drum or tires.
Vibration uses rapid drum movement to reduce friction between particles, allowing them to settle into a denser arrangement. Vibratory rollers are commonly used for soil, aggregate, and asphalt applications.
Kneading action uses specially shaped drum surfaces or tire arrangements to work material from the surface downward. Padfoot and sheepsfoot rollers are particularly useful for cohesive soils.
The goal is not simply to make the surface look smooth. Effective compaction should achieve the required density throughout the specified layer.
Modern machines can also incorporate compaction technology that helps operators monitor machine performance and work toward target density. Caterpillar, for example, offers technology designed to help operators evaluate soil stiffness and visualize compaction progress.
What Are Compactors Used For?
Compactors are used across many construction and infrastructure applications, including:
  1. Road construction
  2. Asphalt paving
  3. Building foundations
  4. Parking lots
  5. Utility trenches
  6. Embankments
  7. Drainage projects
  8. Site preparation
  9. Landfills
  10. Aggregate bases
  11. Soil stabilization
  12. Dams and earthworks
The correct machine depends heavily on the material.
Granular materials such as sand, gravel, and crushed aggregate generally respond well to vibratory compaction. Cohesive soils such as clay often require a kneading action from a padfoot or sheepsfoot drum.
Choosing the wrong machine can result in poor density, excessive passes, wasted fuel, and unnecessary wear.
Main Types of Compactors
1. Smooth-Drum Vibratory Rollers
Smooth-drum vibratory rollers are among the most recognizable compaction machines. They use a steel drum and vibration to compact soil, aggregate, and other materials.
They are particularly useful for granular soils and aggregate bases. Smooth drums are also commonly used in asphalt paving applications where a consistent, relatively smooth finish is required.
Some machines can use optional padfoot shells, allowing a smooth-drum machine to be adapted for additional soil applications.
2. Padfoot Rollers
Padfoot rollers, sometimes called sheepsfoot rollers, use a drum covered with protruding pads.
The pads penetrate cohesive and semi-cohesive soil, creating a kneading effect that helps compact material below the surface.
These machines are commonly used for:
  1. Clay soils
  2. Embankments
  3. Utility work
  4. Foundations
  5. Road bases
  6. Trenching projects
For example, Caterpillar identifies padfoot vibratory soil compactors as suitable for cohesive and semi-cohesive soil applications.
3. Tandem Vibratory Rollers
Tandem rollers use two steel drums—one at the front and one at the rear.
They are commonly used for asphalt and paving applications where contractors need consistent compaction and a smooth finished surface.
Their two-drum configuration also helps distribute compaction across the width of the machine.
4. Pneumatic Rollers
Pneumatic rollers use multiple rubber tires rather than a steel drum.
The tires provide a kneading and pressure effect that can be useful for asphalt, granular materials, and certain soil applications. Tire pressure and machine weight can influence the compaction characteristics.
Pneumatic rollers are particularly useful when a project requires more than simple static or vibratory drum pressure.
5. Vibratory Plate Compactors
Vibratory plate compactors are smaller, walk-behind machines designed for areas where larger rollers cannot easily operate.
They are useful for:
  1. Sidewalks
  2. Driveways
  3. Landscaping
  4. Utility trenches
  5. Small foundations
  6. Paver installations
  7. Confined construction areas
For smaller projects, plate compactors can provide maneuverability that a full-size roller cannot.
6. Trench Rollers
Trench rollers are remote-controlled or walk-behind machines designed for narrow excavation areas.
They are especially useful for compacting soil around utilities, pipelines, foundations, and trenches where a larger roller cannot safely or effectively operate.
7. Landfill Compactors
Landfill compactors are specialized machines designed to spread and compact waste.
They use heavy machines with specialized wheels or drums designed to work through waste material while helping achieve efficient landfill density.
Because landfill operations differ substantially from standard soil and asphalt compaction, these machines should be treated as a specialized equipment category.
Compactor Comparison
How to Choose the Right Compactor
Start with the material, not the machine.
1. Identify the Material
Determine whether you're compacting clay, sand, gravel, aggregate, asphalt, mixed fill, or waste.
Soil type has a major influence on drum selection. Smooth drums are commonly used for granular soils, while padfoot drums are designed for cohesive and semi-cohesive soils.
2. Consider the Required Density
Review the project's compaction specifications before choosing equipment.
The required density may depend on engineering specifications, soil conditions, layer thickness, and the intended use of the finished surface.
3. Match Machine Size to the Job
Larger rollers can cover more material per pass, but they also require more transportation space and operating room.
For residential or confined work, a plate compactor or trench roller may be more practical than a full-size soil compactor.
For major road, earthmoving, and infrastructure projects, a larger vibratory roller can provide the production capacity needed.
4. Consider Drum Type
Drum configuration directly affects performance.
Choose a smooth drum when working primarily with suitable granular materials or paving applications. Consider a padfoot configuration for cohesive soil.
Some machines support interchangeable drum shells, providing additional flexibility for contractors working across multiple applications.
5. Evaluate Operating Weight and Width
Operating weight affects compaction force, while drum width affects how much material the machine can cover during each pass.
A larger machine is not automatically more productive if the jobsite is too confined or the machine is difficult to transport.
6. Look at Technology
Modern compactors may offer features that help operators maintain consistent compaction.
Depending on the machine, technology can include machine monitoring, compaction measurement, mapping, automated vibration controls, and operator-assistance systems.
These features can help crews achieve more consistent results while reducing unnecessary passes.
Buying a Used Compactor: What to Inspect
Buying used heavy equipment can reduce acquisition costs, but condition matters more than the machine's age alone.
Before purchasing a used compactor, inspect the following:
Drum: Check for excessive wear, damage, cracks, or uneven surfaces.
Vibratory system: Test vibration functions and listen for unusual noises.
Hydraulic system: Inspect hoses, cylinders, pumps, and fittings for leaks or damage.
Engine: Look for excessive smoke, leaks, unusual noises, and poor starting performance.
Transmission and drivetrain: Test forward and reverse operation and look for abnormal movement.
Tires: On pneumatic rollers, inspect tire condition, wear patterns, and pressure.
Articulation joint: On articulated machines, check for excessive play or wear.
Operator controls: Confirm that gauges, displays, controls, and safety systems work correctly.
Service history: Review maintenance records and look for evidence of regular servicing.
Hour meter: Compare recorded hours with service documentation and overall machine condition.
A lower-hour machine is not automatically the better purchase. Maintenance history, operating conditions, component condition, and previous applications can tell you much more about the machine's remaining value.
How to Improve Compaction Productivity
Getting the most from a compactor involves more than selecting the right machine.
Operators should maintain consistent travel speed, use the correct vibration settings, monitor material moisture when applicable, and avoid making unnecessary passes.
Layer thickness also matters. Attempting to compact a layer that is too deep for the machine can produce inconsistent density even when the operator makes additional passes.
Jobsite testing and project specifications should ultimately determine whether the required density has been achieved.
Frequently Asked Questions
What is a compactor used for?
Compactors are used to increase the density and stability of soil, aggregate, asphalt, and other materials. Specialized compactors are also used in landfill operations.
What is the difference between a smooth-drum and padfoot compactor?
Smooth-drum compactors are commonly used for granular materials and paving, while padfoot compactors are designed for cohesive and semi-cohesive soils.
What type of compactor is best for clay?
Padfoot or sheepsfoot rollers are commonly used for cohesive soils such as clay because the protruding feet provide a kneading action.
What type of compactor is used for asphalt?
Tandem vibratory rollers, smooth-drum rollers, and pneumatic rollers are commonly used in asphalt paving, depending on the project and required finish.
Is a used compactor worth buying?
A used compactor can be a practical option when its operating condition, maintenance history, specifications, and price match the project's requirements. A thorough inspection is essential before purchasing.
Find the Right Used Compactor for Your Job
The right compactor depends on material type, required density, project size, jobsite conditions, machine configuration, and budget.
Whether you need a smooth-drum roller for roadwork, a padfoot machine for cohesive soil, or a smaller compactor for confined construction areas, matching the machine to the application can help improve productivity and avoid unnecessary operating costs.
Ready to add a compactor to your fleet?
Browse used compactors on Boom & Bucket to compare available machines by make, model, year, hours, specifications, and price.
Shop used compactors
Need help paying for your next machine? Explore equipment financing and review your options before completing your purchase.
Explore financing
Have a compactor or other heavy equipment that is no longer earning its keep? Turn idle equipment into working capital by exploring your selling options.
Sell your used equipment
Javier Bocanegra
