3 Min read
March 28, 2025
Forklifts are essential in warehouses, construction sites, and logistics operations, but they also pose serious safety risks if not handled correctly. One of the most crucial aspects of forklift safety is understanding the forklift stability triangle, which determines how weight is distributed and how a forklift remains stable during operation.
This guide will break down the three points of a forklift that make up the stability triangle, explain how to determine and control forklift stability, and introduce the forklift stability triangle formula to ensure safe handling and accident prevention.
The forklift stability triangle is a key concept in forklift safety that defines the area within which a forklift remains stable. This imaginary triangle is formed by three essential points:
Front Left Wheel
Front Right Wheel
Rear Pivot Point (center of the rear axle)
When the center of gravity remains within this triangle, the forklift remains stable. However, if the center of gravity moves outside the stability triangle—due to excessive tilting, overloading, or uneven terrain—the forklift can tip over.
The forklift and its load have a combined center of gravity. When carrying a load, this center shifts forward. Key factors affecting stability include:
Load weight and distribution
Lift height
Fork position (tilting forward or backward)
Lateral Stability (Side-to-Side): Sudden turns, uneven surfaces, or tilting loads can cause the forklift to tip sideways.
Longitudinal Stability (Front-to-Back): Overloading or lifting loads too high can shift the center of gravity outside the stability triangle, causing a forward tip-over.
Different forklifts have unique designs that affect stability:
Counterbalance forklifts have rear weights to counteract loads.
Narrow aisle forklifts have unique stability considerations due to their design.
Rough terrain forklifts are built for uneven ground, requiring extra caution.
Always check the forklift’s load capacity rating before lifting.
Keep the load as low as possible when moving.
Drive at safe speeds, especially when turning.
Avoid sudden stops and sharp turns.
Distribute loads evenly across the forks.
Understanding the forklift stability triangle formula helps operators calculate safe load handling. The basic formula involves:
Load Center (LC): The horizontal distance from the forks to the center of the load (typically measured in inches).
Rated Load Capacity: The maximum weight the forklift can handle based on its center of gravity.
A typical load center calculation follows this principle: STABILITY = FORKLIFT WEIGHT + (LOAD CAPACITY x LOAD CENTER)
If the combined weight shifts beyond the stability triangle’s perimeter, the forklift becomes unstable.
Overloading Beyond Capacity: Always check the forklift's rated capacity and never exceed it.
Incorrect Load Placement: Keep heavy loads near the mast and avoid unbalanced positioning.
Operating on Uneven Terrain: Drive cautiously on ramps and rough surfaces.
Turning Too Sharply at High Speeds: Slow down and make controlled turns to prevent tipping.
Understanding the forklift stability triangle is essential for safe forklift operation. By recognizing the three points of a forklift that make up the stability triangle, applying the forklift stability triangle formula, and following best practices, operators can reduce the risk of tip-overs and accidents.
Prioritizing forklift stability and safety training ensures a secure working environment, preventing costly damages and injuries. Always stay within the stability triangle and operate with caution to maintain control over your forklift at all times.
For more insights on forklift safety, compliance, and equipment handling, explore our additional resources or consult OSHA guidelines for best practices!
