March 9, 2022
Skid steer weight is one of the most important factors contractors consider before transporting, towing, purchasing, or operating heavy equipment. Machine weight directly affects:
trailer requirements
towing capacity
lifting stability
transport permits
jobsite access
fuel efficiency
Whether you are hauling a compact skid steer for landscaping work or comparing large-frame skid steers for commercial construction, understanding skid steer operating weight helps contractors choose the right machine for their projects.
This guide explains average skid steer weight, model comparisons, towing requirements, and the factors that affect operating weight in 2026.
Browse all Skid steers
Most skid steers weigh between 3,000 and 12,000 pounds depending on machine size, attachments, and operating configuration.
Compact skid steers are lighter and easier to transport, while large-frame skid steers and compact track loaders can exceed 10,000 pounds when fully equipped.
The average skid steer weighs approximately 7,500–8,000 pounds.
Skid steer operating weight varies significantly depending on machine size and intended application.
Skid Steer Size and its Average Weight
Small-Frame Skid Steer - 3,000–6,000 lbs
Medium-Frame Skid Steer - 6,000–7,500 lbs
Large-Frame Skid Steer - 7,500–12,000 lbs
Small skid steers are commonly used for:
landscaping
residential work
light grading
small property maintenance
Larger skid steers are designed for:
heavy material handling
demolition support
earthmoving projects
Many contractors search for skid steer weight by model before transporting or purchasing equipment.
Actual operating weight depends on:
bucket size
tire or track setup
fuel levels
optional accessories
Understanding skid steer weight helps contractors avoid transportation problems and choose equipment that matches jobsite requirements.
Not all trailers can safely transport larger skid steers.
Overloaded towing setups increase:
stopping distance
tire wear
trailer instability
accident risk
Heavier machines can damage:
soft terrain
finished landscaping
residential lawns
Operating weight affects machine balance and lifting performance.
Larger skid steers generally consume more fuel during operation and transport.
One of the most searched contractor questions online is whether a pickup truck can tow a skid steer safely.
truck towing capacity
trailer GVWR
attachment weight
local DOT regulations
Compact and medium-frame skid steers are often towable using:
heavy-duty pickup trucks
gooseneck trailers
dual-axle equipment trailers
However, larger skid steers and compact track loaders may require:
medium-duty trucks
commercial trailers
CDL compliance
Always verify:
axle ratings
brake requirements
hitch capacity
trailer load limits
before transporting heavy equipment.
Many buyers compare skid steers and compact track loaders before choosing equipment.
Wheeled Skid Steer - 3,000–10,000 lbs
Compact Track Loader - 8,000–13,000 lbs
rubber track systems
reinforced undercarriage components
heavier-duty construction
paved surfaces
tight spaces
faster travel speeds
muddy terrain
soft ground
uneven jobsites
Several factors influence skid steer operating weight.
Attachments can significantly increase machine weight.
Examples:
augers
trenchers
forks
hydraulic breakers
grapples
Track-equipped machines generally weigh more than wheeled skid steers.
Enclosed cabs and operator comfort packages may increase total machine weight.
Full tanks and fluid systems add operating weight.
Transporting skid steers safely requires understanding towing limits and trailer capacity.
Skid Steer Size and its Typical Transport Setup
Small Skid Steer - Pickup truck + trailer
Medium Skid Steer - Heavy-duty trailer setup
Large Skid Steer - Commercial hauling equipment
Before transporting a skid steer, contractors should verify:
trailer GVWR
axle capacity
tie-down points
DOT regulations
state permit requirements
Improper hauling can lead to:
equipment damage
trailer failure
expensive fines
unsafe road conditions
Choosing the right skid steer involves balancing:
operating weight
lifting capacity
transport costs
maneuverability
project requirements
Best for:
landscaping
residential work
tight spaces
Ideal for:
utility projects
grading
general construction
Designed for:
heavy lifting
demolition
Many contractors prefer medium-frame skid steers because they balance power, transportability, and operating costs.
Boom & Bucket works with contractors, fleet managers, and equipment buyers across the United States to help customers compare skid steer sizes, transport requirements, operating capabilities, and financing options before purchasing used heavy equipment.
Skid steer weight directly affects:
trailer compatibility
towing safety
hauling regulations
lifting performance
fuel consumption
jobsite flexibility
Understanding these factors helps contractors reduce transportation problems and choose equipment that matches real-world jobsite demands.
Whether you need a compact skid steer for landscaping work or a larger machine for commercial construction, choosing the right equipment starts with understanding operating weight and transportation requirements.
Boom & Bucket helps contractors:
review equipment specifications
browse used skid steer inventory
access financing solutions
arrange equipment transportation
Explore available used skid steers for sale and find the right machine for your next project.
Most skid steers weigh between 3,000 and 12,000 pounds, with average operating weights around 7,500–8,000 pounds.
Small-frame skid steers typically weigh between 3,000 and 6,000 pounds.
Many compact skid steers can be towed using heavy-duty pickup trucks and proper trailers, but larger machines may require commercial hauling equipment.
Skid steer weight affects towing safety, trailer requirements, lifting stability, hauling regulations, and jobsite maneuverability.
Some large-frame skid steers and compact track loaders exceed 11,000–13,000 pounds depending on attachments and configuration.
Yes. Buckets, forks, trenchers, hydraulic breakers, and other attachments can significantly increase operating weight.
More in Insight
