May 18, 2022
Skid steers are among the most versatile and widely used machines in construction, landscaping, agriculture, demolition, snow removal, and material handling. However, even the most reliable skid steer can become a safety hazard if operators skip daily inspections.
A proper skid steer pre-operation inspection helps identify potential mechanical issues before they lead to equipment failures, costly downtime, safety incidents, or OSHA violations. Whether you operate a compact track loader (CTL) or a wheeled skid steer, performing a thorough inspection before every shift is one of the most effective ways to improve safety, productivity, and equipment longevity.
This guide covers everything operators and fleet managers need to know about conducting a skid steer pre-operation inspection.
Browse all Skid steers
A skid steer pre-operation inspection is a systematic review of the machine's condition before it is placed into service.
The goal is to verify that critical systems are functioning properly and identify any issues that could affect:
Machine performance
Jobsite productivity
Equipment reliability
Regulatory compliance
Daily inspections help reduce unexpected breakdowns and extend the life of expensive machine components.
Skipping inspections may save a few minutes, but it can create significant risks.
- Prevent costly equipment failures
- Improve jobsite safety
- Reduce downtime
- Extend machine lifespan
- Protect hydraulic components
- Improve equipment resale value
- Support OSHA compliance
- Lower long-term maintenance costs
Fleet managers often discover that minor issues found during inspections prevent major repairs later.
Before starting the machine, perform a complete walk-around inspection.
Begin with a visual inspection of the entire machine.
Look for:
Cracked welds
Bent components
Loose hardware
Damaged panels
Missing safety decals
Excessive wear on attachments
Even minor damage can become a major repair issue if ignored.
One of the most important steps in a skid steer inspection checklist is evaluating the undercarriage.
Check:
Tire pressure
Sidewall damage
Uneven wear
Missing lug nuts
Inspect:
Rubber track condition
Track tension
Rollers
Idlers
Sprockets
Undercarriage repairs are among the most expensive skid steer maintenance costs, making early detection critical.
Fluid inspections should be performed before starting the machine.
Verify:
Engine oil
Hydraulic fluid
Coolant
Fuel level
DEF fluid (if applicable)
Low fluid levels often indicate leaks or maintenance issues requiring immediate attention.
Hydraulic systems power most skid steer functions.
Inspect:
Hydraulic hoses
Cylinders
Quick couplers
Fittings
Attachment connections
Signs of hydraulic problems include:
Wet spots
Fluid accumulation
Damaged hoses
Cracked fittings
Address hydraulic leaks immediately to avoid system failures and safety hazards.
Attachments significantly affect skid steer performance and safety.
Check:
Mounting points
Locking mechanisms
Hydraulic connections
Wear edges
Pins and bushings
Common attachments include:
Buckets
Grapples
Augers
Forks
Trenchers
Brush cutters
Always ensure attachments are properly secured before operation.
Safety systems should never be overlooked.
Inspect:
Seat belt
Safety bar
Backup alarm
Horn
Mirrors
Lights
Fire extinguisher (if equipped)
These systems protect both operators and nearby workers.
Electrical issues often lead to unexpected downtime.
Inspect:
Battery terminals
Wiring harnesses
Lights
Warning indicators
Gauges
Corrosion, loose connections, and damaged wiring should be repaired immediately.
Open the engine compartment and look for:
Fluid leaks
Damaged belts
Loose hoses
Dirty air filters
Excessive debris
Cleaning debris from the engine area helps reduce overheating risks.
Before starting the machine, inspect the operator station.
Verify:
Clean windows
Functional controls
Working gauges
Proper seat adjustment
Clear visibility
Safety interlocks
A clean and organized cab improves both safety and productivity.
After completing the walk-around inspection, start the machine and monitor system performance.
Check for:
Warning lights
Abnormal engine noises
Excessive exhaust smoke
Hydraulic responsiveness
Steering performance
Brake functionality
Any unusual behavior should be investigated before operating the machine.
Operators frequently identify issues such as:
Finding these problems early can save thousands of dollars in repair costs.
Many contractors underestimate how much money preventive inspections can save.
Hydraulic hose replacement - - - - - - - - - - - - - $150–$1,000+
Hydraulic pump repair - - - - - - - - - - - - - - - - - - $2,000–$8,000+
Track replacement - - - - - - - - - - - - - - - - - - - - - $1,500–$5,000+
Engine repair - - - - - - - - - - - - - - - - - - - - - - - - - - $3,000–$15,000+
Final drive replacement - - - - - - - - - - - - - - - - - $2,000–$8,000+
Spending 10–15 minutes on a daily inspection is far less expensive than dealing with major equipment failures.
Experienced skid steer operators often say the walk-around inspection is the most valuable maintenance habit on any jobsite.
Many costly breakdowns begin with small warning signs:
Minor hydraulic seepage
Loose fittings
Damaged tracks
Low fluid levels
Worn attachment components
Identifying these issues early helps keep machines productive and reduces emergency repair costs.
Modern fleet management systems and telematics tools now support digital inspections.
Popular features include:
Mobile inspection checklists
Digital maintenance records
Fault code monitoring
Real-time equipment alerts
Predictive maintenance tracking
These technologies help contractors improve compliance and reduce equipment downtime.
A skid steer should be inspected before every shift or daily before operation.
Operators should inspect tires or tracks, fluid levels, hydraulic systems, attachments, safety equipment, electrical systems, and the engine compartment.
Pre-operation inspections improve safety, reduce downtime, prevent breakdowns, and extend equipment lifespan.
Most inspections take between 10 and 15 minutes when performed consistently.
Yes. Many contractors now use mobile inspection apps that improve recordkeeping and maintenance tracking.
Hydraulic hose damage and minor fluid leaks are among the most commonly overlooked issues during daily inspections.
A thorough skid steer pre-operation inspection is one of the simplest and most effective ways to improve safety, prevent breakdowns, and maximize equipment performance. By checking fluid levels, hydraulic systems, tracks or tires, attachments, safety devices, and critical machine components before every shift, operators can identify problems early and avoid costly repairs.
For contractors managing multiple machines, consistent inspections are a key part of reducing downtime, controlling maintenance expenses, and improving fleet reliability. Investing a few minutes each day can save thousands of dollars over the life of a skid steer.
Whether you're expanding your fleet or replacing an aging machine, choosing a professionally inspected skid steer can help reduce maintenance surprises and improve long-term productivity on the jobsite.
More in Compact Track Loaders
