How to Get More Hours Out of Heavy Equipment Tires
8 Min read
July 5, 2022
If you're like most construction workers, you rely on heavy equipment to get the job done. And that means keeping your tires in good shape is critical. Unfortunately, even the best tires wear down over time, especially when used heavily. But you can do a few things to make heavy equipment tires last longer. In this blog post, we'll share some tips for extending the life of your heavy construction equipment tires.
Here's a structured table summarizing "How to Get More Hours Out of Heavy Equipment Tires":
This table provides a structured overview of the key points covered in "How to Get More Hours Out of Heavy Equipment Tires," organizing them into sections for easy reference and understanding.
Why is tire maintenance necessary?
Tire maintenance is essential because it keeps your tires in good condition and helps you avoid a blowout. Tire maintenance includes:
  1. checking the pressure
  2. checking the tread
  3. rotating the tires regularly
Checking the pressure is especially important because underinflated tires can lead to a blowout. Checking the tread is also crucial because worn treads can lead to a blowout. Rotating the tires regularly helps to ensure even wear on all of the tires.
Create a tire maintenance plan
Creating a tire maintenance plan for heavy equipment tires is critical to ensuring the safety and longevity of your tires. Here are a few tips to get you started:
  1. Inspect your tires regularly for signs of wear and tear, such as cracks, bulges, or severe tread wear. If you notice any damage, don't hesitate to have your tires repaired or replaced by a professional.
  2. Make sure your tires are inflated to the proper pressure levels. Overinflated or underinflated tires can both lead to premature tire failure.
  3. Avoid excessive speed and braking whenever possible. Both of these habits can put unnecessary stress on your tires and shorten their lifespan.
Ensure you are in sync with the heavy equipment operator and fleet manager to ensure an effective tire maintenance plan. For instance, tire checks can be routinely performed by operators, and any problems with the tires should be reported to the fleet manager.
Choosing the best heavy equipment tires
When choosing heavy equipment tires, the most important factors to consider are the type of ground you'll be operating on and the weight of your machine. Heavier equipment, such as bulldozers and backhoes, require a higher load rating than lighter machines like skid steers
Next, decide what type of terrain you'll be working on. Tires designed for construction or mining sites will have a higher tread depth and greater range of traction than those for paved roads or airports. If your work site is in a remote area, ensure the tires can handle extreme weather conditions.
For soft, muddy, or sandy ground, you'll need tires with deep treads that can grip the surface. For hard surfaces like concrete or asphalt, you'll need tires with a smooth tread so they can slide easily. And for machines that weigh more than 10,000 pounds, you'll need extra-large tires that can support the weight.
Other factors to consider include the climate (hot weather can cause the rubber to melt) and your budget (tires are one of the most expensive components of a machine). So before making a purchase, ensure you research the best ones for your equipment and worksite.
An excellent way to do this is to consult with tire manufacturers to find the best option for your specific application. Many heavy equipment tire manufacturers offer custom-made tires to meet the specific needs of their clients.
How to choose the best tires for Skid Steers?
Skid steer loaders are essential in the realm of heavy equipment, designed for versatility and maneuverability in tight spaces. Choosing the right construction tire for skid steers is crucial for optimal performance. Industrial tires, specifically designed for skid steers, play a pivotal role in ensuring these machines operate efficiently. With options like the skid steer tire, specialized for improved traction and extended wear, operators can navigate construction sites with ease.
Pneumatic tires for skid steers are also noteworthy, providing a smooth ride and puncture resistance. These specialty tires, tailored for skid steers, offer not only durability but also enhanced safety on rough terrains. Features like heat resistance and long wear life are critical considerations in selecting the ideal tire for skid steer loaders.
Importance of Industrial and Pneumatic Tires
Industrial tires
Industrial tires are the foundation of efficient and safe operations. Construction tires for wheel loaders, with specifications like , are designed for heavy-duty tasks. The use of bias tires in industrial applications ensures stability and durability, contributing to the overall performance of construction equipment.
Extended wear life is a key factor in industrial tire selection, ensuring longevity and cost-effectiveness. Backhoe tires and forklift tires fall under this category, addressing specific needs in diverse construction scenarios. These tires, equipped with features such as improved traction and puncture resistance, are indispensable for the demanding requirements of heavy equipment.
Pneumatic Tires
Pneumatic tires are integral to the construction industry, offering a blend of durability and performance. In the context of construction equipment, wheel loaders equipped with pneumatic tires benefit from enhanced traction and a smooth ride. The incorporation of features like puncture resistance ensures longevity and minimizes downtime, crucial in demanding construction environments.
Bias tires, known for their stability, find application in the construction sector providing the necessary support for heavy equipment. Heat resistance is another critical attribute of pneumatic tires, ensuring reliability in diverse working conditions. Whether it's wheel loaders or other heavy machinery, the right pneumatic tire is paramount for operational efficiency.
Why Do Construction Equipment Rely on Heavy Equipment Tires?
Construction equipment relies heavily on specialized tires to meet the demands of various tasks. From backhoe tires to forklift tires, each plays a distinct role in ensuring the smooth functioning of heavy machinery. The incorporation of features like improved traction and puncture resistance is crucial for construction tires, enhancing safety and durability on construction sites.
Wheel loaders equipped with construction tires exemplify the importance of choosing the right tire for specific applications. Factors such as extended wear life and bias tire construction contribute to the overall efficiency of construction equipment, making them indispensable in the ever-evolving construction industry.
Why should you clean heavy equipment tires?
The main reason you should clean heavy equipment tires is to prevent them from wearing down as quickly. If dirt and other debris become embedded in the tire tread, it will cause the rubber to wear down faster. This not only makes your tires less effective but can also be dangerous since a worn-down tire is more likely to blow out while you're driving.
Another reason to clean your heavy equipment tires is that it's crucial for safety reasons. Dirty tires can be very slippery, which could lead to an accident if you're driving or moving the equipment around. Cleaning your tires regularly will help remove all the dirt and debris that can accumulate there and will help keep them in good condition for longer.
Finally, cleaning your heavy equipment tires helps keep them looking good. A nice, clean set of tires makes your equipment look sharp and professional.
Final thoughts
Properly maintaining your heavy equipment tires will not only help them last longer but also keep you safe on the job site. Make sure to have a regular tire maintenance plan in place and always choose the best heavy equipment tires for the task at hand. Regarding safety, don't cut corners -- ensure your tires are up to par. Finally, don't forget that cleaning your heavy equipment tires is integral to keeping them in good condition. Contact Boom & Bucket today for more information on , and let us help you get the most out of your machines!
