How to Operate a Boom Lift: A Comprehensive Guide for Safe and Efficient Use
February 1, 2025
Boom lifts are essential tools for reaching high places on construction sites, maintenance tasks, or other elevated work areas. They offer flexibility, stability, and safety when working at heights, but operating one requires knowledge and responsibility. Whether you’re new to boom lifts or just need a refresher, this guide will walk you through the key steps and safety precautions for operating a boom lift safely and efficiently.
What is a Boom Lift?
A boom lift, also known as an aerial work platform, is a type of elevating platform that uses a hydraulic arm or telescoping boom to lift workers and materials to elevated areas. Boom lifts come in several types, including articulating (knuckle) booms and telescopic (straight) booms. Each type has its own set of advantages depending on the job at hand, but the operating principles remain similar across all models.
Step-by-Step Guide on How to Operate a Boom Lift
1. Pre-Operation Safety Check
Before you even think about lifting the platform, it’s crucial to perform a safety inspection.
  1. Check for any visible damage to the boom lift, including hydraulic hoses, wires, and any signs of wear on the tires or outriggers.
  2. Inspect the platform: Ensure that the platform is free from debris and that all controls are functional.
  3. Check fluid levels: Ensure that the hydraulic fluid, oil, and other necessary fluids are at optimal levels.
  4. Ensure the ground is level: Always operate the lift on firm, level ground. Avoid slopes or unstable surfaces.
  5. Test the emergency lowering mechanism: Ensure it works in case of power failure.
2. Familiarize Yourself with the Controls
Every boom lift is different, but most have standard controls. Familiarize yourself with the following:
  1. Platform controls: These are usually located in the lift basket and control movement in all directions (up, down, extend, rotate).
  2. Ground controls: Located at the base, these allow the operator to control the lift from the ground when needed.
  3. Tilt sensors: Many boom lifts are equipped with tilt sensors that alert you if the machine becomes too tilted.
  4. Emergency lowering controls: These allow you to lower the lift in case of an emergency.
3. Getting Into the Platform
  1. Always use the proper access point to enter the lift platform, usually from the side or a ladder inside the basket.
  2. Never climb up the outside of the boom or use the machine for any unintended purpose.
4. Starting the Boom Lift
  1. Insert the key and turn the ignition to start the lift.
  2. Use the ground controls to move the lift into position, making sure the area is clear of obstacles.
  3. Before elevating, make sure all safety rails are in place and the platform is secure.
5. Raising the Platform
Once you’re safely in the basket:
  1. Use the up/down controls to raise or lower the platform. Start slowly to get a feel for the lift's response.
  2. Monitor the surroundings: Always be aware of obstacles such as overhead power lines, structures, or other workers in the vicinity.
  3. Maintain stability: If your lift has outriggers, extend them for added stability before elevating. Ensure that the lift is level and secure.
6. Maneuvering the Boom Lift
For articulating booms, you’ll need to move the lift in a controlled manner:
  1. Extend and rotate the boom to reach areas that are difficult to access.
  2. Move slowly and carefully: Avoid sudden movements. Smooth, controlled motions are key to maintaining balance and safety.
  3. Use the tilt sensors to ensure the platform doesn’t become unbalanced.
For telescopic booms, you’ll typically only be extending the arm, so make sure to raise the platform in stages, ensuring the lift is stable throughout.
7. Working at Heights
  1. Stay inside the platform at all times. Never lean over the edge or climb on the railings.
  2. Use your tools safely: If you need to carry tools or equipment, secure them properly to avoid accidents.
  3. Don’t overload the platform. Always adhere to the manufacturer’s recommended weight limits.
8. Lowering the Platform
  1. To lower the platform, slowly reverse the process using the down controls.
  2. Ensure the area below the platform is clear of people or obstacles before lowering.
9. Shutting Down the Boom Lift
Once your work is complete, follow these steps:
  1. Lower the platform completely and ensure the lift is on stable, level ground.
  2. Turn off the ignition and remove the key.
  3. Conduct a final check to ensure the lift is properly secured and positioned.
  4. If storing the lift for the day, make sure the controls are locked out, and the lift is parked in a safe, secure location.
Safety Tips for Operating a Boom Lift
  1. Always wear your harness: A fall arrest harness attached to the lift is essential for staying safe while working at height.
  2. Never exceed the weight limit: Overloading the platform can make the lift unstable and increase the risk of tipping over.
  3. Stay clear of power lines: Always maintain a safe distance (at least 10 feet) from power lines and other electrical hazards.
  4. Know the weather conditions: Avoid operating the boom lift during high winds or poor weather conditions that can affect stability.
  5. Follow manufacturer guidelines: Always read and follow the user manual for your specific boom lift model.
Conclusion: Boom Lifts Are Powerful Tools When Used Correctly
Boom lifts are invaluable tools for high-elevation work, but they come with significant responsibility. By following the proper operating procedures and safety precautions, you can ensure a safe and efficient workday. Whether you're on a construction site or performing maintenance, always prioritize safety and take the time to understand your boom lift's capabilities. With the right knowledge and care, you can make the most of this powerful equipment while minimizing the risk of accidents.
