Understanding Project Delivery Methods in Construction: A Guide to Types and Alternatives
3 Min read
March 6, 2025
Selecting the right project delivery method is crucial for ensuring efficiency, cost-effectiveness, and quality in construction projects. Whether you're an owner, contractor, or stakeholder, understanding various project delivery methods in construction can help you make informed decisions. In this guide, we’ll explore different types of project delivery methods and highlight some alternative project delivery methods that are gaining popularity.
What Are Project Delivery Methods?
A project delivery method defines the process by which a construction project is planned, designed, and built. It determines the responsibilities of each party, how risks are distributed, and the contractual relationships between stakeholders. Choosing the right method impacts project timelines, costs, and overall success.
Types of Project Delivery Methods
Each project delivery method in construction has its strengths and weaknesses. Below are the most commonly used types:
1. Design-Bid-Build (DBB)
  1. How it works: The owner hires a designer to complete the project plans, then solicits bids from contractors. The lowest bidder is usually selected.
  2. Pros: Well-established, competitive pricing, clear roles.
  3. Cons: Longer project duration, potential for cost overruns due to change orders.
2. Design-Build (DB)
  1. How it works: A single entity is responsible for both design and construction, streamlining the process.
  2. Pros: Faster project completion, fewer disputes, cost savings.
  3. Cons: Less owner control over design, potential for conflicts of interest.
3. Construction Manager at Risk (CMAR)
  1. How it works: The owner hires a construction manager (CM) early in the process, who assumes financial risk and guarantees project cost.
  2. Pros: Early cost estimates, reduced change orders, better collaboration.
  3. Cons: Higher upfront costs, requires a highly skilled CM.
4. Integrated Project Delivery (IPD)
  1. How it works: All stakeholders, including the owner, designers, and contractors, collaborate under a single contract to maximize efficiency.
  2. Pros: Strong teamwork, reduced waste, shared risk and reward.
  3. Cons: Complex contractual agreements, requires a high level of trust.
Alternative Project Delivery Methods
In addition to traditional methods, alternative project delivery methods offer flexible solutions for various construction needs:
1. Public-Private Partnerships (P3s)
  1. Used for large infrastructure projects where private entities finance, build, and operate public assets.
  2. Pros: Reduces public funding requirements, accelerates project timelines.
  3. Cons: Long-term financial commitments, complex contracts.
2. Job Order Contracting (JOC)
  1. A method for handling multiple small projects through a single long-term contract.
  2. Pros: Faster project execution, cost predictability.
  3. Cons: Limited flexibility for large-scale projects.
3. Bridging Method
  1. Combines elements of DBB and DB, allowing owners to define key design elements before hiring a design-build contractor.
  2. Pros: Maintains owner control while speeding up execution.
  3. Cons: Requires detailed initial planning.
Choosing the Right Project Delivery Method
To select the most suitable method, consider the following factors:
  1. Project size and complexity: Large projects may benefit from IPD or P3s, while smaller projects can use DBB or JOC.
  2. Budget and financing: P3s work well for budget-constrained public projects, while DB offers cost efficiency.
  3. Risk tolerance: Owners who prefer to transfer risk may choose CMAR or DB.
  4. Time constraints: Projects with tight schedules often benefit from DB or IPD.
Trends in Project Delivery Methods
With advances in technology and evolving industry needs, alternative project delivery methods are becoming more common. The use of digital collaboration tools and construction management software is streamlining project execution, improving efficiency, and reducing errors.
Choosing the right project delivery method is essential for the success of any construction project. Whether opting for traditional types of project delivery methods or exploring alternative project delivery methods, understanding each approach’s strengths and limitations will help stakeholders make informed decisions.
By considering project scope, budget, and risk factors, construction professionals can optimize their delivery strategies for maximum efficiency and cost savings.
