9 Min read
April 25, 2023
Asphalt paver technology combines machine controls, sensors, positioning systems, automation, and data tools to help contractors improve paving accuracy, consistency, productivity, and quality.
Modern asphalt pavers can use technologies such as automatic grade control, GNSS/GPS positioning, sonic sensors, automated screed controls, material monitoring, and thermal mapping. These systems don't replace skilled operators. Instead, they provide operators and paving crews with better information and more precise control.
The goal is simple: place asphalt more consistently, reduce rework, improve production, and get more value from every paving project.
For contractors considering new or used paving equipment, understanding what these technologies actually do can make it easier to determine which features are worth paying for.
Browse all equipment
Asphalt paver technology refers to the electronic, hydraulic, sensor-based, and digital systems integrated into modern paving equipment.
These technologies can help control or monitor factors such as:
Grade and elevation
Cross slope
Mat thickness
Paving speed
Screed settings
Material temperature
Material delivery
Machine position
Production data
Modern systems vary significantly by manufacturer, model, year, and configuration. Some features are standard, while others are optional technology packages.
For example, current Cat pavers can offer integrated grade control, hopper-level and temperature monitoring, screed technology, and thermal mapping.
The important point is that paver technology should solve a specific paving problem - not simply add more electronics to the machine.
Grade-control systems help paving crews maintain specified elevations, grades, and cross slopes.
Instead of relying entirely on manual measurements and operator adjustments, sensors and control systems can provide information that helps maintain the desired paving profile.
This can be particularly valuable on projects where pavement elevation and thickness must remain consistent.
Potential benefits include:
Improved grade accuracy
More consistent mat thickness
Less manual adjustment
Reduced rework
Better project consistency
Some modern systems integrate grade control directly into the paver and screed displays.
GNSS-based positioning technology can provide a paver with precise location information.
When combined with digital design data, 3D machine-control systems can help crews maintain specified project elevations and paving parameters.
This can be particularly useful on complex projects involving:
Multiple grades
Variable elevations
Complex roadway designs
Precise slopes
Large paving areas
The value of 3D technology isn't simply knowing where the machine is. It's using positioning and design information to help the crew achieve the intended pavement profile.
Sonic sensors can measure distance to a reference surface without requiring physical contact.
On paving equipment, these systems can help maintain a consistent relationship between the paver and an existing surface or other reference.
This can be useful when contractors need to follow an existing surface while maintaining a desired paving profile.
As with other technologies, the correct setup and calibration are essential. A sophisticated sensor system cannot compensate for poor installation, calibration, or operator practices.
The screed has a major influence on the final asphalt mat.
Modern screed systems can incorporate controls that help manage parameters such as:
Grade
Crown
Cross slope
Screed position
Mat thickness
Extender position
Screed heating
For example, current Cat pavers can integrate grade-control functions with tractor and screed displays, while some models provide programmable paving settings for repeatable jobs.
The objective isn't automation for its own sake. It's repeatability.
Asphalt temperature is an important part of paving quality.
Thermal-monitoring systems can use infrared sensors or cameras to measure surface temperatures as material leaves the screed.
This can help crews identify temperature variations and improve coordination between the asphalt plant, haul trucks, paver, and rollers.
For example, Cat's thermal-mapping technology uses an infrared camera and GNSS positioning to monitor asphalt surface temperatures in real time.
This gives contractors another source of information for identifying potential thermal variation before it becomes a larger quality problem.
Modern pavers can also provide information about material levels and delivery temperatures.
Maintaining consistent material flow is important because interruptions or inconsistent feeding can affect paving continuity.
Some current pavers use hopper-level sensors and temperature indicators to give operators real-time information about incoming material.
This technology works best when combined with good coordination between:
asphalt plant → haul trucks → paver → rollers
Technology can't fix an inefficient paving train by itself.
Connected equipment can provide useful operational information about the machine and paving process.
Depending on the system, contractors may be able to monitor:
Operating hours
Production rates
Machine location
Paving parameters
Temperature information
Maintenance data
Fuel consumption
The biggest opportunity is turning this information into better decisions.
Collecting data without using it doesn't improve productivity.
The best technology depends on the project. A contractor doing straightforward paving work may not need every available system, while a contractor handling large, high-specification projects may benefit substantially from advanced machine control and monitoring.
The real value of paving technology comes from improving the entire paving operation.
Grade-control systems can help crews maintain the intended pavement profile and reduce deviations.
Automated controls and monitoring can help maintain more consistent paving parameters.
More accurate placement can reduce the likelihood of costly corrections later.
Monitoring material delivery and temperature can help crews identify problems earlier.
Technology gives operators additional information while allowing them to focus on machine operation and jobsite conditions.
Digital machine data can help contractors understand what happened during a paving operation and identify opportunities for improvement.
Buying a technologically advanced paver doesn't automatically make a paving operation more efficient.
Here are seven ways to get more value from the technology.
Don't pay for features your projects don't require.
Consider the specifications, tolerances, job size, terrain, paving width, and production requirements.
Operators need to understand what the technology is measuring, what the displays mean, and how to respond when conditions change.
Incorrect calibration can undermine the accuracy of otherwise sophisticated systems.
Follow the manufacturer's setup and calibration procedures.
Inspect sensors, cables, displays, controls, and other electronic components as part of regular machine maintenance.
A paver can't maintain continuous production if trucks arrive inconsistently or material supply is interrupted.
Look for patterns in production, temperature, machine performance, and downtime.
Technology works best when combined with proper material handling, screed setup, paving speed, operator training, and roller coordination.
A used paver can provide significant value, but buyers need to look beyond the machine's age and operating hours.
Before buying, inspect:
Screed condition
Screed heating system
Augers
Conveyors
Hydraulic components
Hopper
Sensors
Displays
Electronic controls
Thermal-monitoring equipment
Operating hours
Maintenance history
Previous repair work
This is especially important.
A used paver may be advertised as having grade control or another technology package, but buyers should verify exactly what is installed and whether the system is functional.
Ask:
What technology is installed?
Is it factory-installed or aftermarket?
Is the hardware complete?
Does the display function properly?
Are the sensors present and operational?
Is documentation available?
A machine with advanced technology that doesn't work isn't necessarily a bargain.
It depends on your operation.
Technology may provide a stronger return when a contractor regularly performs:
High-volume paving
High-specification roadway work
Complex grades
Large paving projects
Projects where rework is expensive
Work requiring detailed documentation
For simpler paving jobs, a contractor may get better value from investing in a reliable machine with the right screed and essential controls rather than paying for every available technology package.
The right question isn't “How much technology can we get?”
It's:
“Which technology will improve the economics and quality of our paving operation?”
That shift in thinking can prevent contractors from overbuying technology they won't actually use.
Paving technology is becoming increasingly connected, automated, and data-driven.
Future developments are likely to focus on:
Greater machine automation
Improved grade control
Connected paving fleets
Real-time quality monitoring
More advanced thermal mapping
Digital project models
Machine-to-machine communication
Lower-emission equipment
AI-assisted equipment management
The trend is less about replacing skilled paving crews and more about giving operators better information and greater control.
Asphalt paver technology includes sensors, machine controls, positioning systems, automation, monitoring equipment, and digital tools designed to improve paving accuracy, consistency, productivity, and quality.
Common technologies include automatic grade and slope control, GNSS positioning, 3D machine control, sonic sensors, automated screed controls, thermal monitoring, material monitoring, and machine-data systems.
3D paving technology combines positioning information with digital design data to help equipment maintain specified elevations, grades, slopes, or other project parameters.
It can improve productivity by reducing manual adjustments, improving consistency, identifying problems earlier, and helping crews coordinate the paving process. However, technology alone cannot overcome poor material delivery, setup, maintenance, or crew coordination.
It can be, especially for contractors working on high-volume or high-specification projects. Buyers should verify which technology is installed, whether it works properly, and whether the expected productivity and quality benefits justify the additional cost.
Inspect the screed, augers, conveyors, hydraulics, sensors, displays, controls, heating system, operating hours, maintenance history, and any integrated grade-control or thermal-monitoring technology.
The best paving technology isn't necessarily the most expensive technology.
It's the technology that helps your crew pave more accurately, maintain consistent quality, reduce rework, and keep the job moving.
Whether you're upgrading an existing fleet or buying a used asphalt paver, focus on the features that match your actual projects.
Not sure which paver configuration fits your work?
Learn more about asphalt paver types, sizes, features, and buying considerations before choosing your next machine.
→ Explore the Asphalt Paver Buying Guide
Looking for a paver with the technology your crew needs?
Browse Boom & Bucket's selection of used pavers and compare machines by make, model, hours, specifications, condition, and price.
A productive paving operation requires more than the paver. Explore used compactors, cold planers, road reclaimers, and other construction equipment to build a complete paving fleet.
More in Insight
