Quick Guide to Paver Installation: Concrete Road, Patio, and Pavers Stones
11 Min read
Mike Kennedy
Mike Kennedy
Marketplace Operations Manager, Boom & Bucket
September 14, 2023
Pavement installation offers a versatile way to enhance various outdoor spaces, from functional concrete roads and sidewalks to cozy patios and decorative paving stones. Although many people only think of the giant trucks that pave roads, many other types of paver installation can be used to decorate your home and outdoor spaces.
In this guide, we'll explore three main pavement types, providing insights into their uses, required supplies, machinery, and their respective advantages and disadvantages.
What Is Paver Installation?
Paver installation is the process of preparing a surface and placing individual pavers to create a durable area for patios, walkways, driveways, roads, and other outdoor applications.
A typical installation includes site preparation, excavation, base installation, bedding material, paver placement, edge restraints, joint sand, and compaction. Proper drainage and a stable base are essential for long-term performance.
Section 1: Concrete Road and Sidewalk Pavement
When most people hear of paver installation, roads, and sidewalks come to mind. These can be made with either concrete, primarily made from concrete sand, or asphalt, primarily made from a mixture of gravel and excess sand.
While it is considered one of the more "basic" ways to lay pavers, it is also one of the most functional and crucial for modern society.
Best Used for:
Concrete pavers are ideal for constructing durable and long-lasting roads and sidewalks. It's commonly employed in urban and suburban areas for both pedestrians and vehicular traffic.
Unlike some other types of paver projects, concrete pavers will require machinery like a vibrating plate compactor and a concrete blade. That, combined with the fact that you'll be laying the pavers over a larger area, means that laying pavers for this project will be quite a bit more expensive than others. You may also need to hire a professional team to install pavers, which can further increase the overall cost of the paver project.
Supplies Needed:
You'll need a few different materials and machinery to pour concrete or install pavers, like a concrete mixer and a vibrating plate compactor. You'll also need the actual materials like polymeric sand to make the concrete or asphalt mixture.
  1. Concrete Mix: The primary material for concrete pavement (bedding sand, gravel)
  2. Reinforcement Bars (Rebar): Enhances structural strength.
  3. Forms: Used to mold and contain the concrete.
  4. Finish Tools: Trowels, brooms, or power screeds for smoothing the surface.
  5. Expansion Joint Material: To prevent cracking.
  6. Curing Compound: Helps concrete cure properly.
Machinery:
  1. Concrete Mixer: For mixing the concrete.
  2. Concrete Pump or Truck: Transports and pours the concrete.
  3. Vibrating Screed: Ensures a level and smooth surface.
  4. Concrete Saw: Cuts expansion joints.
Installation Process
The installation process for standard concrete paving used in driveways, sidewalks, and roads typically involves several key steps. Firstly, site preparation is essential. This involves clearing the area of any existing debris, vegetation, or old pavement. The ground is then graded to ensure proper drainage and a level surface. Sub-base material, such as crushed stone or gravel, is laid and compacted to provide a stable foundation for the concrete.
Once the sub-base is prepared, forms are set up to define the shape and dimensions of the pavement. Reinforcement may also be added, especially in high-traffic areas, using materials like rebar or wire mesh to enhance the concrete's strength. The concrete mix is poured into the forms and carefully leveled and smoothed using various tools.
After the concrete cures, finishing touches like jointing, texture, or coloring can be applied as desired. Proper curing is crucial for concrete strength and durability. Regular maintenance, such as sealing and crack repair, helps prolong the life of the concrete pavement, ensuring it serves its intended purpose effectively and safely for years to come.
Pros and Cons
Positives:
- Durability: Concrete pavements can last for decades, even under heavy traffic.
- Low Maintenance: They require minimal upkeep.
- Smooth Surface: Provides a comfortable and safe walking/driving experience.
Negatives:
- Initial Cost: Installation can be more expensive.
- Cracking: May develop cracks over time, which require maintenance.
- Hard Surface: Less forgiving for falls.
Section 2: Patio Pavement
Having a beautiful outdoor area in your home is a great way to encourage your family to use your outdoor space and increase the value of your home.
There are many different paver patio options that you can use for your patio, but one of the most popular is stamped concrete pavers. They are made with fine polymeric sand and paver edging to create the desired pattern. Installing pavers like this is a more affordable way to have a beautiful paver area in your backyard.
They are also DIY-friendly, making it a great home renovation project that can greatly increase the value of your home.
Best Used For:
This type of paver project is best for creating an inviting outdoor living space that is perfect for relaxation, dining, and other social gatherings. Patio pavers are a great way to take a fully natural outdoor space and create a functional and aesthetically appealing space with a few simple tools and materials.
Patio paver installation is also one of the easier types of pavement to use. It is relatively easy to lay patio pavers; most people can do so without professional help or equipment. This can help save money and be a fun project for the whole family to get involved in.
Supplies Needed:
  1. Pavers or Patio Blocks: Various materials, including concrete, clay, or natural stone.
  2. Sand or Gravel Base: Creates a stable foundation.
  3. Edge Restraints: Secures the pavers in place.
  4. Joint Sand: Fills gaps between pavers.
  5. Leveling Tools: To ensure a flat surface.
  6. Paver Sealer (optional): Enhances appearance and durability.
Machinery:
A plate compactor may be used to compact the base.
When installing standard concrete paving for a patio, the process is somewhat similar to other concrete applications but tailored to the specific requirements of an outdoor living space. Firstly, the area is prepared by clearing it of any vegetation or debris. A proper sub-base is established, typically consisting of crushed stone or gravel, which is compacted to create a stable foundation that can withstand outdoor elements and the weight of patio furniture.
Once the sub-base is in place, concrete is poured into forms that define the patio's shape and size. Reinforcement, such as wire mesh or rebar, may be added for added strength. The concrete surface is leveled and smoothed to ensure an even and attractive finish. After curing, additional steps in the design process can be applied, such as stamping.
Stamped concrete involves impressing patterns or textures onto the surface to mimic the appearance of natural stone, brick, or other materials. This design element can significantly enhance the patio's aesthetics, providing a unique and appealing look to the outdoor space. Proper sealing and ongoing maintenance help preserve the beauty and longevity of the stamped concrete patio.
Pros and Cons
Positives:
- Versatility: Numerous materials, colors, and patterns are available.
- Easy Repairs: Individual pavers can be replaced if damaged.
- DIY-Friendly: Suitable for many skill levels.
Negatives:
- Weed Growth: Weeds may sprout between pavers if not properly maintained.
- Occasional Unevenness: Individual pavers can shift or settle unevenly over time.
Section 3: Paving Stones
Finally, if you truly want a beautiful and unique outdoor space, paving stones are a great option that often has a warmer feel to it than regular or stamped concrete. If you choose to use natural stones, you can expect to pay quite a bit more than you would for regular concrete paving stones. This is because the stones have to be sourced, transported, shaped, and then transported again before they can be sold. Some types of natural stone are also more desirable than others, resulting in an elevated price.
Best Used for:
Paving stones, or interlocking pavers, are commonly used for driveways, walkways, and decorative outdoor surfaces.
Supplies Needed:
  1. Paving Stones: Available in various materials like concrete, brick, or natural stone.
  2. Sand Bed: Provides a level base for the stones.
  3. Edge Restraints: Holds the stones in place.
  4. Joint Sand: Fills gaps between the stones.
  5. Paver Sealer (optional): Enhances appearance and longevity.
  6. Rubber Mallet: Helps push border stones and paver joints into place
Machinery:
- A plate compactor is used to compact the sand base and secure the stones in place.
The installation process for paving stones to create a patio or walkway is meticulous and labor-intensive. It begins with excavation and preparation of the area, removing existing materials, and ensuring proper drainage. A base layer of crushed stone or gravel is then spread and compacted to establish a stable foundation. This compacted base layer is crucial for natural stone and concrete block pavers to prevent shifting and settling.
One key difference between natural stones and concrete blocks lies in their uniformity. Natural stones often have irregular shapes and sizes, requiring more attention during installation to ensure a level surface and tight fit. In contrast, concrete block pavers are manufactured with consistent dimensions, simplifying the installation process.
Other than that, natural stones offer a rustic and organic aesthetic, while concrete blocks provide a more uniform and modern appearance. The choice between the two depends on the desired look and the project's specific requirements.
Regardless of the type of paver, the next steps involve laying the stones or blocks in the desired pattern and filling the gaps with sand or gravel. Lastly, the surface is compacted to secure the pavers in place.
Pros and Cons
Positives:
- Design Options: Wide variety of colors, shapes, and patterns.
- Durability: Resistant to cracking and wear.
- Easy Maintenance: Repairs are straightforward.
Negatives:
- Cost: Paving stones can be more expensive than concrete.
- Weed Growth: Like patio pavers, weeds may emerge between the stones.
- Professional Installation: Complex patterns may require skilled installation.
Common Paver Installation Mistakes
Avoiding common installation errors can improve durability and reduce future repairs. Frequent problems include:
  1. Inadequate excavation
  2. Poor subgrade compaction
  3. Insufficient or improperly compacted base
  4. Incorrect drainage or slope
  5. Uneven bedding material
  6. Missing or weak edge restraints
  7. Incorrect joint material
  8. Insufficient final compaction
Follow manufacturer installation requirements and address drainage and foundation issues before placing the pavers.
How Much Does Paver Installation Cost?
Paver installation costs vary based on the project size, paver material, site preparation, excavation depth, base requirements, labor, drainage, design complexity, and equipment needs.
Additional costs may include demolition or removal, delivery, cutting, edging, grading, drainage improvements, and site restoration.
For an accurate estimate, calculate both material and labor requirements and account for site-specific preparation work.
Paver Maintenance Tips
Regular maintenance can help preserve the appearance and performance of a paved surface. Recommended practices include:
  1. Remove dirt, leaves, and debris regularly.
  2. Address weeds growing between joints.
  3. Replace damaged or displaced pavers.
  4. Refill joint material when necessary.
  5. Check drainage and low areas.
  6. Clean stains using appropriate methods.
  7. Inspect edge restraints and surface movement.
Follow the paver manufacturer's cleaning and maintenance recommendations.
Expert Insights on Paver Installation
Successful paver installation depends on proper site preparation, subgrade stability, base depth, drainage, bedding material, edge restraints, and compaction. The right installation method can vary based on soil conditions, climate, traffic loads, and whether the project is a patio, walkway, driveway, or other paved surface.
Frequently Asked Questions About Paver Installation
What goes under pavers?
A typical paver installation uses a compacted subgrade, aggregate base, and bedding material beneath the pavers. The exact design depends on the application, soil, drainage, and manufacturer requirements.
How deep should you dig for paver installation?
Excavation depth varies according to the paver application, soil conditions, base requirements, and expected loads. Follow the manufacturer's installation specifications and applicable local requirements.
Do pavers need a base?
Yes. A properly designed and compacted base provides stability and helps reduce settling, shifting, and drainage problems.
Do you need sand under pavers?
Bedding material is commonly used beneath pavers to create a consistent installation surface. The specific material and thickness should follow the paver manufacturer's recommendations.
What is the best equipment for installing pavers?
Equipment depends on project size. A plate compactor and basic hand tools may be sufficient for small projects, while larger installations may require skid steers, compact track loaders, mini excavators, loaders, or material-handling equipment.
Choosing the right pavement type for your project depends on its purpose and budget. Concrete pavement is best suited for roads and sidewalks due to its durability but comes with a higher initial cost. Patio pavement offers flexibility and is DIY-friendly but may require occasional maintenance. Paving stones provide design versatility and durability, making them ideal for driveways and decorative surfaces.
Each pavement type has its own set of advantages and disadvantages, so consider your specific needs and preferences before embarking on your pavement project. Whether you're creating a smooth road, a cozy patio, or an intricate stone design, the right choice can enhance your outdoor space's functionality and aesthetics.
Mike Kennedy
