3 Min read
June 11, 2024
When it comes to navigating challenging terrains and demanding job sites, Terramac's straight frame crawler carriers stand out as industry leaders. These machines are designed to handle environments that traditional wheeled vehicles simply can't conquer, making them indispensable assets for a variety of industries. Here’s why Terramac’s straight frame crawler carriers, particularly the RT6, RT9, and RT14 models, excel in tough terrains.
One of the most significant advantages of Terramac's crawler carriers is their rubber track technology. Unlike wheeled vehicles, which can struggle on soft or uneven ground, the rubber tracks on Terramac carriers disperse the machine’s weight over a larger surface area. This results in exceptionally low ground pressure, allowing these machines to traverse sensitive or unstable terrains without causing damage. Whether you’re working in wetlands, on sandy soils, or other delicate environments, Terramac’s rubber tracks ensure you can move efficiently while minimizing your environmental impact.
Terramac’s straight frame crawler carriers offer unparalleled versatility with multiple bed options to suit a variety of job requirements. Whether you need to transport everyday materials, haul rugged materials, or move oversized items, there’s a bed configuration for you:
Dump Bed: Ideal for moving dirt, sand, and other everyday materials.
Flat Bed: Perfect for transporting oversized items such as mats and poles.
Rock Bed: Designed to handle heavy-duty materials, ensuring you can tackle the toughest jobs with ease.
This adaptability makes the RT6, RT9, and RT14 incredibly valuable across a range of industries, from construction and excavation to environmental restoration and mining.
Durability is crucial when working in harsh conditions, and Terramac's commitment to using high-quality components ensures that their crawler carriers stand up to the toughest environments. Key areas like the undercarriage are built to withstand extreme conditions, ensuring a long service life and reducing downtime. This focus on quality means you can rely on Terramac carriers to perform consistently, job after job.
Each model in the straight frame lineup offers impressive performance specifications tailored to different needs:
RT6: With a 12,000 lbs. carrying capacity and 155 hp @ 2200 rpm, the RT6 is perfect for smaller job sites where maneuverability and efficiency are key. It operates with a ground pressure of just 5.3 psi when loaded.
RT9: This model boasts an 18,000 lbs. carrying capacity and 225 hp @ 2200 rpm, making it ideal for medium-sized projects. It operates with a ground pressure of 6.4 psi when loaded, balancing power and mobility.
RT14: For the most demanding jobs, the RT14 offers a 28,000 lbs. carrying capacity and 310 hp @ 2200 rpm. Despite its heavy-duty performance, it maintains a ground pressure of 7.4 psi when loaded, ensuring it can handle even the toughest terrains.
Terramac’s straight frame crawler carriers have proven their worth in real-world applications. For example, the RT6 has been instrumental in infrastructure improvements along California’s Crystal Cove State Park. Its ability to carry materials up steep, loose sand hills—where standard tire vehicles would fail—highlights its superiority in challenging environments.
In summary, Terramac's straight frame crawler carriers provide unparalleled advantages for tough terrains. Their low ground pressure, versatile bed options, high-quality components, and superior performance make them the go-to choice for industries needing reliable and efficient machinery. Whether you’re dealing with construction, environmental restoration, or any other demanding field, Terramac’s RT6, RT9, and RT14 models ensure you have the capability to get the job done right.
