Tree Spade: A Game-Changer for Tree Relocation
February 17, 2025
Tree transplantation is a crucial practice in landscaping, forestry, and construction. Instead of removing mature trees, professionals now use tree spades to relocate them efficiently. A tree spade is a specialized machine designed to dig, lift, and transport trees with minimal root disturbance, ensuring their survival in a new location. This technology is widely used in urban planning, land development, and reforestation projects.
In this guide, we’ll explore how a tree spade works, its different types (including skid steer tree spades, Bobcat tree spades, and tree spade trucks), and the benefits of using them in construction and landscaping.
What Is a Tree Spade?
A tree spade is a mechanical device equipped with curved steel blades that encircle the tree's root system, cut through the soil, and extract the tree with its root ball intact. This allows the tree to be relocated and replanted without significant damage to its root structure, improving its chances of survival.
Key Features of a Tree Spade:
  1. Hydraulic-powered blades for precise digging and lifting.
  2. Adjustable blade sizes to accommodate different tree diameters.
  3. Attachment compatibility with various machinery like skid steers and trucks.
  4. Durable steel construction to withstand rugged environments.
How Does a Tree Spade Work?
Using a tree spade follows a step-by-step process to ensure a successful tree relocation:
  1. Positioning the Tree Spade – The operator aligns the tree spade around the tree’s trunk to ensure balanced extraction.
  2. Blade Penetration – The spade’s sharp blades insert into the ground and encircle the root ball, cutting through the soil.
  3. Lifting the Tree – Hydraulic systems lift the entire tree and its root ball from the ground.
  4. Transporting the Tree – The extracted tree is placed onto a transport vehicle or directly into its new planting hole.
  5. Replanting and Aftercare – The tree is positioned in the new location, backfilled with soil, and watered to encourage root establishment.
Different Types of Tree Spades
Tree spades come in different configurations based on their intended use and the type of machinery they attach to.
1. Skid Steer Tree Spade
A skid steer tree spade is a compact and maneuverable option, ideal for landscaping companies and nurseries. These attachments fit onto skid steer loaders and are perfect for relocating small to medium-sized trees.
Advantages:
  1. Easy to operate in tight spaces.
  2. Quick tree relocation for landscaping projects.
  3. Cost-effective for smaller operations.
2. Bobcat Tree Spade
A Bobcat tree spade is a specific type of skid steer tree spade designed for use with Bobcat skid steers. Bobcat’s advanced hydraulic system allows for precise control and efficient tree extraction.
Advantages:
  1. Enhanced stability and control.
  2. Compatible with Bobcat’s quick-attach system.
  3. Available in various blade sizes for different tree diameters.
3. Tree Spade Truck
A tree spade truck is a heavy-duty vehicle equipped with a large tree spade attachment, capable of relocating fully matured trees. This option is commonly used in large-scale landscaping, commercial developments, and reforestation projects.
Advantages:
  1. Can transport large trees over long distances.
  2. Suitable for municipal and commercial tree relocation.
  3. Reduces manual labor and speeds up large-scale projects.
Choosing the Right Tree Spade for Your Needs
When selecting a tree spade, consider the following factors:
  1. Tree size: Larger trees require bigger spades with deeper penetration.
  2. Soil type: Some soils are harder to penetrate, requiring stronger hydraulic force.
  3. Equipment compatibility: Ensure the spade fits your existing skid steer, truck, or loader.
  4. Project scale: For small landscaping jobs, a skid steer tree spade may be sufficient, while large projects may require a tree spade truck.
Benefits of Using a Tree Spade in Landscaping and Construction
Using a tree spade offers several advantages, making it a valuable tool in urban development, reforestation, and construction.
1. Faster and Safer Tree Relocation
Traditional tree transplantation methods can take hours and pose a higher risk of tree damage. A tree spade significantly reduces transplanting time while keeping the root system intact.
2. Cost-Effectiveness and Labor Savings
Manual tree digging is labor-intensive and expensive. Tree spades reduce workforce requirements and minimize the costs associated with tree replacement.
3. Environmental Benefits
Preserving mature trees improves air quality, reduces soil erosion, and maintains the ecological balance of an area. Instead of cutting down trees for construction, relocating them with a tree spade promotes sustainability.
Maintenance and Safety Tips for Operating a Tree Spade
To ensure the longevity and efficiency of your tree spade, follow these maintenance and safety guidelines:
Maintenance Tips:
  1. Regularly inspect hydraulic lines for leaks or wear.
  2. Keep blades sharp to ensure clean cuts.
  3. Lubricate moving parts to prevent rust and wear.
  4. Clean the spade after each use to prevent soil buildup.
Safety Tips:
  1. Always wear protective gear when operating heavy machinery.
  2. Ensure the spade is correctly aligned before engaging the hydraulic blades.
  3. Avoid overloading the spade beyond its capacity.
  4. Train operators on proper usage to prevent accidents.
Tree spades are essential tools for anyone involved in landscaping, construction, and environmental conservation. Whether you're using a skid steer tree spade, a Bobcat tree spade, or a tree spade truck, these machines offer a fast, efficient, and eco-friendly way to relocate trees without causing damage.
By selecting the right tree spade and following proper maintenance and safety protocols, you can ensure successful tree transplantation and contribute to sustainable land development.
If you're in the construction or landscaping industry, investing in a tree spade can revolutionize the way you handle tree relocation projects. Start integrating tree spades into your workflow today and experience their efficiency, cost savings, and environmental benefits firsthand!
