Various Bulldozer Attachments
November 8, 2022
You probably think that bulldozers are only useful for clearing away debris and excavating earth, but you'd be surprised by the number of other tasks this nifty piece of machinery can handle. It's not just about pushing things around; a bulldozer can also help you with cutting, lifting, loading, smoothing, grading, and many more tasks.
This piece of equipment's versatility makes it so popular among construction companies. The use of bulldozer attachments further extends the versatility of a bulldozer. These accessories give your machine new capabilities which may not have been achievable otherwise.
Let's explore some of the most common bulldozer attachments and how they can make your bulldozer even more useful.
Rotary Cutter
A rotary cutter is a cutting attachment fitted to the front of a dozer. This attachment allows the machine to cut through thick materials like roots, vines, and reeds. This attachment is also helpful when performing precision grading, rail bed construction, and many other tasks.
An average rotary cutter attachment consists of a heavy-duty cutting drum that rotates at high speeds, a support bracket, a water supply system, and a number of cutting heads. These cutting heads are what do the actual cutting. Rotary cutters are available in various sizes, each suited to a specific bulldozer model.
Stabilizer
Stabilizers are used for grading and grading applications, such as road construction, grading dirt roads, and creating access paths for construction equipment. When used with a bulldozer and an appropriate cutting head, these attachments are used to grade and smooth the surface of your work area.
Stabilizers typically consist of two long metal bars placed on either side of the dozer track. This helps the track maintain a straight line, even on uneven ground or when working on soft soil. Stabilizers are available in various sizes, depending on the size of your bulldozer.
Breaker / Scraper
A breaker attachment allows you to break up and smooth the surface of existing land, while a scraper attachment helps you smooth and level the surface of newly cleared areas. Both these attachments are used in grading applications and are sometimes referred to as finishing attachments.
A breaker attachment consists of a curved scraper bar in front of the dozer blade. When the dozer is pushed forward, the curved scraper bar breaks up and smooths the surface that the bulldozer is passing over.
A scraper attachment is essentially a set of heavy-duty metal blades mounted on the front of the bulldozer. When the bulldozer is pushed forward, these blades smooth and level the surface of freshly cleared land.
Grapple Bucket
A grapple bucket attachment allows you to pick up and move loose materials such as rocks, gravel, sand, and soil. This attachment can be used for grading applications and is particularly useful when grading soil, as it creates level ground. You can also use a grapple bucket to move smaller objects such as bricks, concrete blocks, and steel bars.
A grapple bucket consists of a large scoop attached to the front of the dozer. The dozer moves forward, and the front scoop scoops up the materials to be moved. These materials are then held in the scoop, ready to be moved to another location. A grapple bucket typically has two controls. One controls the scoop, and the other controls the bucket spout, which is used to direct materials into a specific spot.
Hook and Go Platform (HGP)
These are specialized platforms designed to carry materials such as pipes and cables or loads too heavy for the dozer to carry. A hook and go platform consists of a large platform fitted to the front of the dozer. This platform is attached to a crane, allowing you to move large and heavy objects easily.
Hook-and-go platforms are particularly useful when laying pipes. Pipes are often difficult to move and may get trapped when pulled behind a bulldozer. A hook-and-go platform carries the pipes along the ground, and a crane is used to raise them up and over obstacles as they are moved between locations.
Hook-and-go platforms are available in various sizes and are designed to fit specific models of bulldozers. These attachments allow you to do more with your bulldozer, as you can now easily move extremely heavy objects.
Vibratory Bowl Folder
A vibratory bowl folder helps you to smooth the surface of freshly cleared land. When the dozer is pushed forward and the bowl folder is lowered to the ground, it vibrates and breaks up the soil, which allows it to be folded over onto itself, creating a smooth and level surface.\ Vibratory bowl folders are available in various sizes, each designed to fit a specific bulldozer model. These attachments are handy when grading freshly cleared land with high clay content.
Hydraulic Cutter
A hydraulic cutter attachment is a heavy-duty cutting attachment used to cut through thick and dense materials. This attachment can be used to cut roots, vines, and reeds. You can also cut through thick steel cables, chains, and other heavy materials commonly found on construction sites.
A hydraulic cutter attachment is placed just behind the dozer blade. It uses a powerful hydraulic cutting head to slice through tough materials. A hydraulic cutter attachment is a heavy-duty attachment typically only used in challenging situations where other attachments may not cut through the material.
Here's a table showcasing various bulldozer attachments:
Please note that the price ranges for these attachments can vary greatly depending on factors such as size, brand, and additional features.
The dozer is a versatile piece of construction equipment that is useful in almost any situation. Whether you are clearing land, building a road, or working in a confined area, a dozer attachment can help you get the job done better and faster.
Bulldozer attachments extend the versatility of this piece of equipment even further, allowing it to do things that it might not have been able to do otherwise. Browsing through the above list of dozer attachments, you'll notice that there is a dozer attachment for almost every situation. Choose the right one, and you can make your dozer even more helpful.
