Best Excavator Attachments
octubre 31, 2022
Virtually every construction site needs an excavator. They serve many purposes, including dredging, clearing brush, digging, demolition, mining, landscaping, and just about any job you can imagine. A major reason for an excavator's versatility is all of its attachments; attachments help workers be more productive and work more efficiently on the work site.
Attachments are quick and easy to switch out and can completely transform an excavator to accommodate all of your needs. Today we'll review some of the best excavator attachments to enhance your equipment's functionality and versatility even with a used excavator machine as well.
Auger Drills
Auger drills are designed with spiraled blades that grab onto materials; they clear out a precise hole. They are flexible and are used to drill through pavement, earth, wood, or ice. Augers range from 4 inches to 4 feet in length, while some can even dig up to 33 feet down. These are ideal for drilling holes for trees, building foundations, and pillars. Depending on the size, quality attachments and capability of the auger you choose, you can expect to pay between $2,500 and $3,000 for this attachment.
Buckets
Buckets are one of the most common excavator attachments. They are made of hard teeth with teeth running along the edge and are used to dig into the ground and scoop out the earth. When you visualize an excavator, chances are that you picture it with a bucket. Buckets can vary in size, weight and shape and are primarily used to scoop up and transport materials. There are a variety of bucket types to suit virtually any need. Some of the most popular types of buckets include:
  1. General bucket
  2. Dirt bucket
  3. Rock bucket
  4. Heavy-duty bucket
  5. Light materials bucket
  6. Low-profile bucket
Whether you need your excavator to pick up debris or remove rocks, a simple bucket attachment will work wonders in getting the job done quickly and efficiently. With the right attachments and bucket style, you may find you'll be able to increase productivity and minimize operating costs. Depending on the size of your excavator and the type of bucket you choose, the price can range from about $1,500 to upwards of $15,000.
Trenchers
If you need precision digging, a trencher will be an invaluable tool on your job site. Trenchers are much more precise than a standard bucket attachment and can save your company significant time and money. As their name suggests, trenchers are used for digging trenches, making them the most appropriate solution over other excavator attachments. For comparison purposes, you would need much more time and fuel to use two to four excavators with bucket attachments than using just one trencher.
Trenchers are also useful in refining the backfill and can return to the trench without sinkage. Many equipment owners overlook that trenchers can be used close to buildings and other objects, which makes them ideal for more difficult jobs. You can expect to pay between $4,000 to $6,000 for a trencher attachment.
Ripper
A ripper is a very simple-shaped attachment with a pointed tip. It's used to rip into the ground or other hard or frozen surfaces; a ripper is a powerful tool that can easily rip up earth, as well as embedded objects such as root systems, fences or tree stumps. Most ripper attachments cost between $1,000 to $3,000.
Hammer
A hammer attachment is ideal if you need to break up a large surface such as a stone or a large slab of concrete. Also known as a breaker or hammer-breaker, it works similarly to a jackhammer by using high impact to cut through the material quickly and efficiently. Hammer attachments come in various shapes, and the option you choose will depend a lot on the material you will need to break up. Some of the most common hammer attachment types include:
  1. Moil
  2. Chisel
  3. Blunt
Depending on the type of hammer attachment case you plan to choose, you can expect the price range to be between $3,000 to $5,000.
Grading Blade
Rather than purchasing a grader, you can choose a grader attachment for your excavator to level out the ground. This will help prepare a flat surface for your project without having to invest in a new machine. You can adjust the angle of the blade and the height to help you achieve the right level of surface grade. Grading blade attachments come in many sizes to accommodate a variety of machines and terrains. With several different mounting configurations and sizes, the price of grading blades typically falls between $700 to $3,000.
Thumbs
A thumb is a large clamp that presses down on the materials inside of a bucket to hold them in place. It is helpful for holding onto odd-shaped materials that do not fit neatly into the bucket, such as tree stumps and demolition debris. Although it is most common on demolition sites, you can also use it for other applications. Many thumb attachments cost between $150 to $600, depending on the size needed.
Mulchers
Mulchers are popular forestry attachments used in managing vegetation at a job site. They can cut through vegetation, undergrowth, and other organic materials and turn them into mulch. They are effective in mulching anything from undergrowth to small trees. They serve a great dual purpose of removing unwanted vegetation while producing a biodegradable material that can either be used on the job site or sold for a profit. Since mulcher attachments are more complex, the prices vary greatly and can run anywhere between $10,000 to upwards of $39,000.
Grapple
Although a grapple is a popular excavator attachment in forestry work, it is also useful for construction, waste handling, and demolition jobs. A grapple uses two large, curved clamps and grabs onto oddly-shaped materials. There are a couple of different types - one that allows you to move both sides and one that moves just one side. No matter which type of grapple you use, it is typically controlled by hydraulics, so you can change the angle, pull, or rotation of the attachment. Most grapple attachments cost somewhere between $800 and $4,000.
Flail Mower
Some landscaping jobs are too complex for a regular mower. For these tough tasks, a flail mower is used to cut difficult vegetation such as shrubs or tall grass. Additionally, the mowing flails can bounce off stationary objects such as the road or rocks, which prevents the mower from throwing these objects and causing damage to surrounding structures. Flail mowers are easy to maintain, as you can sharpen or replace the individual cutters. Flail mowers can cost anywhere between $2,000 and $7,000.
Delving Deeper into Excavator Attachment Benefits
Excavator attachments stand as the unsung heroes of construction, providing an arsenal of specialized tools that transform these machines into versatile powerhouses. Their diverse capabilities significantly impact efficiency and project success.
  1. Efficiency Amplification: The versatility offered by excavator attachments cannot be overstated. Auger drills, for instance, provide precision in hole-making, whether it’s for planting trees or foundational work. Their ability to adapt to different materials like wood, ice, or pavement showcases their versatility. This adaptability streamlines tasks that would otherwise require separate specialized machinery.
  2. Cost-Effectiveness and Time Savings: The financial aspect cannot be overlooked. Trenchers, with their precision in digging trenches, represent a cost-effective alternative, saving both time and fuel compared to using multiple excavators with bucket attachments. Similarly, the grading blade, providing surface leveling without the need for a separate grader machine, offers significant cost savings.
  3. Project Precision and Environmental Benefits: Attachments like mulchers and flail mowers serve dual purposes, effectively managing vegetation while producing biodegradable mulch. This not only enhances project precision but also contributes to environmental sustainability, offering a responsible way to handle organic waste.
  4. Adaptability for Versatile Construction Needs: The adaptability of excavator attachments caters to various construction domains. Whether it's demolition, waste handling, forestry, or intricate landscaping, these attachments, from grapples to rippers, adjust to the project’s unique demands, thereby increasing the machine’s utility across diverse construction sectors.
  5. Future Trends and Innovations: The world of excavator attachments is constantly evolving, with technological advancements driving innovations. As industry demands change, the attachments market continually adapts, offering more efficient and specialized tools to meet the evolving needs of construction professionals.
Here's a table summarizing the best excavator attachments mentioned in the article:
This table provides a quick overview of each excavator attachment, including its price range and key features.
Here's the countdown for the best excavator attachments:
  1. Attachment: Auger Drills
    Price Range: $2,500 - $3,000
    Features: Designed with spiraled blades for precise hole drilling. Flexible and suitable for drilling through various materials. Ideal for drilling holes for trees, building foundations, etc.
2.Attachment: Buckets
Price Range: $1,500 - $15,000
Features: Common attachment for digging and scooping earth. Available in various types (e.g., general, dirt, rock, heavy-duty). Enhances productivity and minimizes operating costs.
3.Attachment: Trenchers
Price Range: $4,000 - $6,000
Features: Precise digging for trenching tasks. Saves time and fuel compared to multiple excavators with bucket attachments. Useful for refining backfill and working near buildings.
4. Attachment: Ripper
Price Range: $1,000 - $3,000
Features: Pointed tip for ripping into hard or frozen surfaces. Powerful tool for ripping up earth and embedded objects. Enhances efficiency in earthmoving and demolition tasks.
5.Attachment: Hammer
Price Range: $3,000 - $5,000
Features: Breaks up large surfaces like stones or concrete slabs. Comes in various types (e.g., moil, chisel, blunt). Suitable for different materials and demolition applications.
6.Attachment: Grading Blade
Price Range: $700 - $3,000
Features: Levels out ground surfaces efficiently. Adjustable angle and height for precise grading. Cost-effective alternative to purchasing a separate grader machine.
This countdown provides a concise summary of each excavator attachment, including its name, price range, and key features.
A Final note
In the realm of construction, excavators stand as the ultimate multi-functional machines. Their adaptability ability and efficiency are significantly bolstered by the myriad attachments available. Understanding the diversity and functionalities of these attachments not only enhances project productivity but also ensures cost-effectiveness, making every construction task more manageable.
By choosing the right excavator attachments, construction professionals can optimize and expand their equipment’s capabilities, adapting to the ever-changing needs of different projects. Whether it's a used excavator or a brand-new one, the right attachment can significantly boost efficiency, thereby elevating the overall construction experience.
