Popular Tri-Fuel Generators for Your Power Backup Needs
2 Lectura mínima
enero 17, 2025
When it comes to ensuring your home or business remains powered during an outage, tri-fuel generators are an excellent choice. These versatile machines run on gasoline, natural gas, and propane, giving you flexibility depending on the availability of fuel. Here are some of the most popular tri-fuel generators you can consider for your power needs:
1. Duromax XP15000HXT
The Duromax XP15000HXT offers impressive performance with a peak power of 15,000 watts when running on natural gas. It's an excellent choice for those needing a reliable and robust generator that can handle large appliances, such as air conditioners, refrigerators, and more.
2. Champion 201161
The Champion 201161 provides 12,000 watts of running power on gasoline, 10,000 watts on natural gas, and 15,000 watts of peak starting power. This generator is a great option if you’re looking for a balanced power solution that can handle multiple household devices while offering flexibility in fuel options.
3. Westinghouse WGEN20000TFC
For those seeking heavy-duty backup power, the Westinghouse WGEN20000TFC offers an impressive 20,000-watt peak power, with 16,000 watts running on natural gas and a starting surge of 22,400 watts. It's an excellent option for larger homes, farms, or small businesses in need of significant backup power.
4. MicroAire Easy Start Flex 398
If you already own a generator but are struggling with starting large appliances like air conditioners, the MicroAire Easy Start Flex 398 is a game-changer. This soft start kit reduces inrush surge by as much as 60-70%, allowing your generator to handle larger loads and ensuring smoother startup for sensitive equipment like AC units. This is particularly helpful if you are trying to run a 5-ton AC unit using a smaller generator.
Choosing the Right Tri-Fuel Generator for You
Tri-fuel generators offer unparalleled flexibility and convenience for power backup. Whether you're looking for a high-powered solution for a large home or a smaller option for your emergency needs, these popular generators cater to a range of budgets and requirements. The key to selecting the best one lies in assessing your household or business's power needs and understanding how each model handles running and starting power on different fuels.
With options from brands like Duromax, Champion, and Westinghouse, you're sure to find a tri-fuel generator that suits your needs and budget. Consider your environment and fuel availability, and you're all set to stay powered during outages with ease!
