4 Lectura mínima
abril 10, 2025
Choosing the right windows for a new construction project is essential for energy efficiency, durability, and overall aesthetics. Unlike replacement windows, new construction windows are installed directly into the frame of a building before walls and siding are finished. Whether you're constructing a home or a commercial building, selecting the best windows for new construction ensures long-term performance and cost savings. In this guide, we'll cover the best windows for new home construction, compare options for commercial buildings, and explore the new windows installation process and equipment used.
When selecting the best windows for new construction, consider these critical factors:
Look for Low-E (low emissivity) glass, which helps reflect heat while letting in natural light.
Double or triple-pane windows with argon gas insulation provide superior thermal efficiency.
ENERGY STAR-certified windows can reduce heating and cooling costs.
Vinyl Windows: Affordable, low maintenance, and energy efficient.
Fiberglass Windows: Highly durable, resistant to temperature changes, and long-lasting.
Aluminum Windows: Strong and lightweight but may require thermal breaks to improve insulation.
Wood Windows: Offer classic aesthetics but need more maintenance.
Choose materials suited to your climate—fiberglass and vinyl perform well in extreme temperatures.
Impact-resistant glass is ideal for hurricane-prone areas.
Various frame finishes and colors are available to match your home’s style.
Smart windows with UV protection and self-tinting capabilities offer modern convenience.
For homeowners, the best windows for new home construction balance cost, efficiency, and aesthetics. Some top residential window choices include:
Traditional style, easy to clean, and great for ventilation.
Hinged at the sides, providing excellent airflow and energy efficiency.
Ideal for modern homes; they offer large, unobstructed views.
Add architectural interest and increase natural light inside the home.
Top Brands for Residential Windows: Andersen, Pella, Marvin, Simonton, Milgard.
Commercial buildings require high-performance windows that can withstand weather changes and heavy use. Some of the best options include:
Large glass panels designed for retail and office spaces.
Used in high-rise buildings, providing structural support and modern aesthetics.
Essential for hurricane-prone areas and buildings requiring extra security.
Top Brands for Commercial Windows: Kawneer, YKK AP, Winco, EFCO.
Installing new windows for a building requires precision, proper tools, and, in some cases, heavy equipment. Below is an overview of the new windows installation process and equipment used.
Framing Preparation – Ensuring the rough opening is level and structurally sound.
Sealing & Flashing – Applying weatherproof barriers to prevent leaks.
Window Placement – Securing the window in the opening with shims.
Fastening & Insulation – Using screws and caulk to ensure a tight seal.
Finishing Touches – Installing exterior trim and sealing gaps for energy efficiency.
Cranes & Boom Lifts – Essential for multi-story buildings and large glass panels.
Suction Lifters & Glass Manipulators – Prevents damage and ensures safety while handling large windows.
Scaffolding & Ladders – Provides stable access for workers installing windows on high structures.
Forklifts & Material Handlers – Moves heavy window materials efficiently on construction sites.
The cost of new windows installation varies depending on factors like material, labor, and equipment used. Here’s a rough breakdown:
Factors that affect pricing include:
Window size and type (custom designs cost more).
Number of windows installed (bulk installations may reduce per-unit costs).
Additional features (impact-resistant glass, energy-efficient coatings, etc.).
Selecting the best windows for new construction requires careful consideration of energy efficiency, durability, and cost. Key takeaways:
Choose the right material for longevity and maintenance ease.
Invest in energy-efficient windows to reduce utility bills.
Hire professionals and use the right equipment for safe and efficient new windows installation.
By using the right best windows for new home construction or commercial projects, you ensure comfort, security, and energy efficiency. Ready to start your project? Get quotes from trusted window installation companies today!
