Bobcat S630 vs. Kubota SSV75: Which is best?
3 Lectura mínima
julio 26, 2023
When choosing between the Bobcat S630 and the Kubota SSV75, there are several factors to consider to determine which skid-steer loader is the best fit for your needs. Both machines are highly regarded in the industry, offering robust performance, reliability, and versatility.
Engine Power
Both the Bobcat S630 and the Kubota SSV75 are equipped with a 74.3 HP engine, ensuring they deliver comparable power and performance for demanding tasks.
Operating Weight and Capacity
The Kubota SSV75 is slightly heavier, with an operating weight of 8,157 lbs compared to the Bobcat S630's 7,593 lbs. This weight difference translates into a higher rated operating capacity for the SSV75, which can handle 2,690 lbs, whereas the S630 can handle 2,180 lbs. This makes the Kubota a better choice for heavier lifting and more demanding applications.
Lift Type and Height
Both machines use a vertical lift type, which is ideal for loading and carrying tasks that require high lift and reach. However, the Kubota SSV75 has a higher hinge pin height at 128.3 inches compared to the Bobcat S630's 121 inches, giving it a slight edge in reach and loading height.
Fuel Tank Capacity
The Bobcat S630 has a slightly larger fuel tank at 23.9 gallons compared to the Kubota SSV75's 23.5 gallons. While this difference is minimal, it may contribute to longer operating periods between refueling.
Hydraulic Flow
The Kubota SSV75 offers a marginally higher hydraulic flow at 20.9 GPM compared to the Bobcat S630's 20.7 GPM. This can result in slightly better performance when using hydraulic attachments.
Travel Speed
One of the significant differences between these two models is their travel speed. The Kubota SSV75 has a top speed of 11.1 mph, significantly faster than the Bobcat S630's 7.1 mph. This makes the SSV75 a better option for applications that require frequent movement over larger distances.
Price
The price range for the Bobcat S630 is between $45,000 and $55,000, while the Kubota SSV75 ranges from $50,000 to $60,000. While the Kubota is slightly more expensive, the additional features and capacities might justify the higher price for some users.
Choosing between the Bobcat S630 and the Kubota SSV75 depends on your specific needs and budget.
Bobcat S630: Offers excellent performance and reliability at a slightly lower cost, making it a great option for those on a tighter budget or those who do not require the highest operating capacities.
Kubota SSV75: Provides higher lifting capacity, faster travel speed, and greater lift height, making it ideal for more demanding tasks and larger job sites.
Both models are excellent choices, but the Kubota SSV75 might be the better option if your operations demand higher performance and you are willing to invest a bit more upfront.
