Case TR340 vs. Bobcat T770: Which is best?
2 Lectura mínima
julio 26, 2023
When choosing between the Case TR340 and the Bobcat T770, it's important to consider their specifications, features, and overall performance to determine which machine best suits your needs. Here's a detailed comparison to help you decide:
Detailed Comparison
Performance
blogContentCTA.title
blogContentCTA.description
The Bobcat T770 has a slight edge in engine power, with 92 hp compared to the 90 hp of the Case TR340. This difference, though minor, can contribute to slightly better performance in demanding tasks. Both machines have similar rated operating capacities and tipping loads, making them comparable in terms of lifting and carrying capabilities.
Weight and Size
The Case TR340 is slightly lighter, with an operating weight of 10,000 lbs compared to the Bobcat T770's 10,515 lbs. Both machines have similar dimensions and travel speeds, offering good maneuverability and ease of transport.
Hydraulics
The Case TR340 offers higher hydraulic flow rates both in standard and high-flow modes. This can provide better performance when using hydraulic attachments, making the Case TR340 more versatile for various tasks that require strong hydraulic power.
Ground Pressure
The Bobcat T770 has a lower ground pressure of 4.2 psi compared to the Case TR340's 5.0 psi. Lower ground pressure is beneficial when working on soft or sensitive surfaces, as it reduces the risk of ground damage and improves stability.
Fuel Efficiency
The Bobcat T770 has a slightly larger fuel tank capacity of 27.2 gallons compared to the 25.5 gallons of the Case TR340. This allows for longer operating hours without refueling, potentially increasing productivity on larger job sites.
Pricing
Prices for these machines can vary based on the year, configuration, and additional features. As of the most recent data, new Case TR340 models typically range from $60,000 to $75,000, while new Bobcat T770 models range from $70,000 to $85,000​ (Construction Equipment Guide)​​ (Machinery Pete)​.
Choosing between the Case TR340 and the Bobcat T770 will depend on your specific needs and priorities:
Case TR340: Higher hydraulic flow rates make it ideal for tasks requiring powerful hydraulic attachments. Slightly lighter and potentially more versatile in certain applications.
Bobcat T770: Slightly more powerful engine, lower ground pressure, and a larger fuel tank make it well-suited for extended use on softer surfaces and larger job sites.
Both machines offer excellent performance and reliability, making them suitable choices for various construction and landscaping tasks.
