Compact Telehandlers: A Complete Guide to Sizes, Features, and Differences
4 Lectura mínima
marzo 27, 2025
A compact telehandler is an essential piece of equipment for construction, agriculture, and material handling. Combining the lifting power of a forklift with the reach of a crane, compact telehandlers provide versatility in tight spaces. But how do they compare to other machines, and what factors should you consider when choosing one?
In this guide, we’ll cover the popular list of compact telehandlers, the standard size of telehandlers, and answer the question: What is the difference between a compact wheel loader and a telehandler?
What is a Compact Telehandler?
A compact telehandler is a smaller, more maneuverable version of a standard telehandler, designed for job sites with limited space. It features a telescopic boom that allows for vertical and horizontal lifting, making it ideal for lifting materials over obstacles or into elevated areas.
Key Features of Compact Telehandlers:
  1. Telescopic Boom: Extends forward and upward for precise material placement.
  2. Compact Size: Designed for maneuvering in restricted spaces.
  3. Versatile Attachments: Compatible with buckets, forks, winches, and platforms.
  4. Four-Wheel Drive & Steering: Ensures better traction and mobility on rough terrain.
Popular List of Compact Telehandlers
Choosing the right compact telehandler depends on lifting capacity, boom reach, and job site requirements. Below are some of the most popular compact telehandlers available today:
1. JCB 505-20E
  1. Lift Capacity: 5,500 lbs
  2. Maximum Lift Height: 20 ft
  3. Key Feature: Fully electric with zero emissions
2. Manitou MT 625
  2. Maximum Lift Height: 19.5 ft
  3. Key Feature: Compact design with a tight turning radius
3. Bobcat TL619
  2. Maximum Lift Height: 19 ft
  3. Key Feature: Powerful diesel engine for rough terrain
4. Genie GTH-5519
  3. Key Feature: Lightweight and easy to transport
5. Caterpillar TH255C
  2. Maximum Lift Height: 18.4 ft
  3. Key Feature: Robust frame for durability in construction sites
Standard Size of Telehandlers
Understanding the standard size of telehandlers helps determine the right model for your needs.
Compact Telehandler Dimensions:
  1. Height: 6.5 – 7.5 ft
  2. Width: 5 – 6.5 ft
  3. Lift Height: 18 – 20 ft
  4. Load Capacity: 5,000 – 6,000 lbs
Mid-Size Telehandler Dimensions:
  1. Height: 7.5 – 9 ft
  2. Width: 7 – 8 ft
  3. Lift Height: 30 – 50 ft
  4. Load Capacity: 6,000 – 12,000 lbs
Heavy-Duty Telehandler Dimensions:
  1. Height: 9 – 10 ft
  2. Width: 8 – 10 ft
  3. Lift Height: 50+ ft
  4. Load Capacity: 12,000 – 20,000+ lbs
What is the Difference Between a Compact Wheel Loader and a Telehandler?
Both compact wheel loaders and telehandlers are used for material handling, but they serve different purposes.
Compact Wheel Loader:
  1. Designed for scooping and loading bulk materials.
  2. Fixed lifting arm with a bucket or forks.
  3. Best for ground-level loading and transport.
  4. Limited vertical reach.
Compact Telehandler:
  1. Equipped with a telescopic boom for extended reach.
  2. Can lift materials both vertically and horizontally.
  3. Ideal for stacking pallets, lifting loads to higher levels.
  4. More versatile with multiple attachment options.
When to Choose a Telehandler Over a Wheel Loader:
  1. Need to place materials at elevated heights.
  2. Require greater reach over obstacles.
  3. Working in tight job sites with limited maneuverability.
Key Features to Look for in a Compact Telehandler
When selecting a compact telehandler, consider the following factors:
  1. Lift Capacity & Reach – Ensure it meets your job site requirements.
  2. Maneuverability – Tight turning radius for confined spaces.
  3. Attachments & Versatility – Forks, buckets, and work platforms increase functionality.
  4. Fuel TypeDiesel for power, electric for emissions-free operation.
  5. Operator Comfort & Safety – Enclosed cab, ergonomic controls, and stability systems.
Benefits of Using a Compact Telehandler
1. Enhanced Efficiency
  1. Reduces manual labor and speeds up material movement.
2. Space-Saving Design
  1. Works efficiently in narrow and confined spaces.
3. Versatility in Application
  1. Adapts to various tasks with interchangeable attachments.
4. Cost-Effective Solution
  1. More affordable than larger telehandlers while providing similar functionality.
Choosing the Right Compact Telehandler for Your Needs
To find the best compact telehandler, consider:
  1. Job Site Terrain – Rough terrain models for uneven surfaces.
  2. Lift Height Requirements – Match specifications with project needs.
  3. Attachment Compatibility – Choose a model that supports essential add-ons.
  4. Rental vs. Purchase – Renting for short-term projects, buying for long-term use.
Cost Range of Compact Telehandlers
  1. New Models: $50,000 – $100,000+
  2. Used Models: $30,000 – $70,000
  3. Rental Rates: $150 – $500 per day / $1,000 – $3,500 per month
A compact telehandler is a versatile and essential machine for lifting, loading, and material handling in construction and agriculture. Understanding the popular list of compact telehandlers, standard telehandler sizes, and the differences between telehandlers and compact wheel loaders ensures you choose the right equipment for your needs.
Whether you’re looking for a high-reach telehandler for construction or a maneuverable model for farm work, selecting the right compact telehandler can significantly enhance productivity on your job site.
Looking for compact telehandlers for sale or rent? Compare prices from top brands and find the best telehandler for your project today!
