The Cat 308 Excavator: A Powerful and Versatile Machine
junio 30, 2023
The Cat 308 Excavator is a game-changer when it comes to heavy-duty construction equipment. Whether you're a seasoned excavator operator or just beginning your career in the construction industry, the Cat 308 offers a range of benefits and advantages that you won't find in other excavators. From its powerful digging capabilities to its eco-friendly features, the Cat 308 is designed to enhance performance and optimize efficiency in construction projects of all sizes. Let's take a closer look at what makes the Cat 308 Excavator so special.
Overview of the Cat 308 Excavator
The Cat 308 Excavator is a mid-size model in the Cat excavator lineup, weighing approximately 20,000 pounds. It's designed for versatility and can tackle a wide range of jobs, from digging and excavating to grading and demolishing. It's the perfect choice for contractors who need a reliable and efficient machine that can handle tough jobs. The performance and machine adjustments of the Cat 308 hydraulic excavator can be improved by the addition of a reversible wear edge boom and a coat hook cup holder. The minimum configuration of an excavator's loader includes steel tracks, hand levers cat key, and only one pin position.
Key Features and Specifications
The Cat 308 Excavator is loaded with features that set it apart from other models in its class. Here are just a few of the standout features that make the Cat 308 a top choice:
  1. Engine output: 67 horsepower
  2. Operating weight: 20,000 pounds
  3. Maximum digging depth: 16.2 feet
  4. Maximum reach: 24.3
  5. Hydraulic digging forces: 12,500 lbf (boom) / 7,830 lb (stick)
Applications and Industries
The Cat 308 Excavator is ideal for a vast range of applications, including Site development and preparation. The maximum weight that the air conditioning system in this vehicle can handle is 1,000 pounds. It is also capable of recording high-definition video.
  1. Utility work
  2. Landscape and hardscaping
  3. Demolition
Thanks to its versatile design, the Cat 308 can also be customized with various attachment options, including buckets, hammers, and thumbs, to suit the unique demands of your job.
Enhanced Performance and Efficiency
When it comes to construction equipment, performance and efficiency are key. The Cat 308 Excavator delivers on both fronts, with powerful digging capabilities and eco-friendly features.
Powerful Digging Capabilities
The Cat 308 is equipped with a range of features that give it top-notch digging capabilities. Its hydraulic system delivers a digging force of 12,500 pounds (boom) and 7,830 pounds (stick) for maximum power and speed. It also has a digging depth of up to 16.2 feet and a reach of up to 24.3 feet, allowing it to tackle a wide range of excavation tasks with ease. The automatic engine idle control system is designed to maintain a constant fuel tank flow to the engine at idle, even as flow rises pressure goes down.
Fuel Efficiency and Eco-Friendly Features
The Cat 308's eco-friendly features are a significant benefit for operators, as they offer reduced fuel consumption and lower emissions. The Cat 308 is designed with a fuel-efficient engine that delivers optimal performance without sacrificing fuel economy.
Comfort and Ease of Operation
Operating heavy equipment can be demanding work, which is why the Cat 308 Excavator is designed for comfort and ease of use. From its ergonomic operator station to its advanced control system, the Cat 308 offers a range of features that make it a top choice for operators.
Ergonomic Operator Station
The Cat 308's operator station is designed with comfort and safety in mind. The seat is fully adjustable and the controls are within easy reach, making it easy to find the perfect operating position. The cabin is also equipped with climate control, ensuring a comfortable working environment, no matter the weather.
Advanced Control System
The Cat 308's advanced control system makes it easy to install the system and for operators to work efficiently and accurately. The system is equipped with joystick controls that allow for smooth, precise movements and the ability to operate multiple functions at once. The optional automated machine control (AMC) feature for the generation advanced monitor option (AMO) includes auxiliary hydraulic lines for improved performance.
Versatility and Customization
One of the most significant benefits of the Cat 308 Excavator is its versatility. Contractors can use the machine for a range of tasks and customize it with various attachments to suit the unique needs of their job site. The Cat 306 CR mini excavator features a Next Generation Color LCD monitor with Cat Stick Steer, providing the operator with clear and concise information about the machine's performance, including maximum dig height. External enclosure doors are used to protect electrical and electronic equipment from the elements.
Attachment Options and Compatibility
The Cat 308 is compatible with a wide range of attachments, including buckets, hammers, thumbs, and more. These attachments allow operators to perform a range of tasks with a single machine, eliminating the need for additional equipment.
Configurations for Different Job Sites
The Cat 308 comes in a range of configurations to suit different job sites. Whether you need a compact machine for tight spaces or a more substantial model for heavy-duty jobs, the Cat 308 has you covered.
Safety and Durability
Safety and durability are critical factors when it comes to heavy construction equipment. The Cat 308 Excavator is designed with safety in mind and built to last, even under the most challenging conditions.
Built-In Safety Features
The Cat 308 is equipped with a range of built-in safety features, including:* Rearview camera and monitor
  1. Travel alarm
  2. Emergency stop button
  3. Operator presence system
These features help ensure the safety of both the operator and those around the machine monitoring the job site.
Long-lasting Components and Design
The Cat 308's components are designed with durability in mind. From its strong steel frame to its hard-wearing tracks and undercarriage, the Cat 308 is built to withstand the rigors of heavy-duty use and last for years to come.
The Cat 308 Excavator is a top-performing machine that offers a range of benefits and advantages for contractors. With its powerful digging capabilities, eco-friendly features, and customizable design, the Cat 308 hydraulic excavator is the ideal choice for construction projects of all sizes. Whether you're excavating, grading, or demolishing, the Cat 308 is designed to help you work efficiently and safely, ensuring the success of your project from start to finish. You have also the opportunity to look at the different models of used excavators at a glance.
