Everything you need to know about pipelayer pl87
junio 11, 2023
The PL87 pipelayer is a powerful and versatile piece of equipment that can be used to lay large-diameter pipes. It is a valuable asset for any construction company that needs to lay pipes for water, sewer, gas, or other utilities.
The PL87 is easy to operate and reliable, making it a safe and efficient choice for pipelaying projects. Join us as we delve into the features and benefits of this remarkable equipment, designed to streamline and enhance your pipelaying projects.
What is a pipelayer?
A pipelayer is a worker who lays pipes. They use heavy machinery to dig trenches, position pipes, and seal joints. Pipelayers work on a variety of projects, including water and sewer systems, gas lines, and oil pipelines. The job requires strong math and problem-solving skills, as well as the ability to work safely in hazardous environments.
Why is the PL87 pipelayer important?
The PL87 pipelayer is an important piece of equipment for a variety of reasons. It is a powerful and versatile machine that can be used to lay large-diameter pipes. It is also easy to operate and reliable, making it a safe and efficient choice for pipelaying projects.
The PL87 pipelayer is a valuable asset for any construction company that needs to lay large-diameter pipes. It is a powerful, versatile, and reliable piece of equipment that can help you complete your projects on time and budget.
Features and Specifications
It is a valuable asset for any construction company that needs to lay pipes for water, sewer, gas, or other utilities. The PL87 is easy to operate and reliable, making it a safe and efficient choice for pipelaying projects. Here is a brief overview of the features and specifications of the PL87 pipelayer:
Engine
The Cat C15 ACERT engine is a Tier 4 Final engine that meets the latest emissions standards. It is also a fuel-efficient engine that can help you save money on operating costs.
Lift capacity
The PL87's lift capacity of 216,000 pounds means that it can handle pipes of up to 48 inches in diameter and up to 100 feet in length. This makes it a versatile machine that can be used for a variety of pipelaying projects.
Slope capability
The PL87's slope capability of 30 degrees means that it can be used in a variety of terrain conditions. This makes it a valuable asset for construction companies that need to lay pipes in difficult areas.
Side-to-side stability
The PL87's side-to-side stability of 10 degrees means that it is less likely to tip over, even when working on uneven terrain. This makes it a safe machine to operate, even in challenging conditions.
Ease of operation:
The PL87 is designed to be easy to operate, even for inexperienced operators. It has a joystick control system that makes it easy to position the boom and the pipe. This can help you save time and money on training costs.
Reliable performance:
The PL87 is a reliable machine that is built to withstand the rigors of construction work. It is backed by a comprehensive warranty that provides peace of mind. This can help you avoid costly downtime and repairs.
Overall, the PL87 pipelayer is a powerful, versatile, and reliable piece of equipment that can be used for a variety of pipelaying projects. It is a valuable asset for any construction company that needs to lay large-diameter pipes.
Applications
These are some of the important applications of the PL87 Pipelayer machine.
Pipeline construction
Pipelines are used to transport water, oil, and gas over long distances. The PL87 pipelayer can be used to lay large-diameter pipes for pipelines. This is a critical application, as pipelines are essential for the transportation of essential resources.
Sewer and water main installation
Sewer and water mains are essential infrastructures that provide essential services to communities. The PL87 pipelayer can be used to install and repair sewer and water mains. This is a vital application, as it ensures that communities have access to clean water and sewage disposal services.
Foundation work
Foundations are the base of buildings, bridges, and other structures. The PL87 pipelayer can be used to lay the foundation for these structures. This is an important application, as it ensures that structures are stable and safe.
Other heavy civil construction projects:
The PL87 pipelayer can be used for a variety of other heavy civil construction projects, such as road construction, bridge construction, and dam construction. This is a versatile application, as the PL87 can be used for a variety of different projects.
The PL87 pipelayer is a powerful and versatile piece of equipment that can be used for a variety of applications. It is a valuable asset for any construction company that needs to lay large-diameter pipes.
Cost and Availability
The cost of a PL87 pipelayer varies depending on the specific model and options. A base model PL87 pipelayer typically costs around $1 million. However, the cost can increase significantly if you add additional features or options, such as a longer boom, a heavier-duty winch, or a more powerful engine.
The PL87 pipelayer is available for purchase from Caterpillar dealers worldwide. If you are interested in purchasing a PL87 pipelayer, you should contact your local Caterpillar dealer for more information.
Factors Affecting the Cost Pipelayer PL 87
Here are some of the factors that can affect the cost of a PL87 pipelayer:
  1. Model: The cost of a PL87 pipelayer varies depending on the specific model. For example, the PL87D is a more advanced model than the PL87C, and it is, therefore, more expensive.
  2. Options: The cost of a PL87 pipelayer can also increase if you add additional features or options. For example, a longer boom can cost several thousand dollars, and a heavier-duty winch can cost even more.
  3. Location: The cost of a PL87 pipelayer can also vary depending on the location where it is purchased. For example, PL87 pipelayers are typically more expensive in Europe than they are in the United States.
Career Opportunities
Pipelayers are in high demand, and there are many career opportunities available. Pipelayers can work for construction companies, government agencies, or private businesses. The job outlook for pipelayers is good, and the pay is competitive. Here are some of the specific career opportunities available to pipelayers:
  1. Construction companies: Construction companies are always looking for qualified pipelayers to help with their projects. Pipelayers can work on a variety of projects, including water and sewer systems, gas lines, and oil pipelines.
  2. Government agencies: Government agencies also need qualified pipelayers to help with their projects. Pipelayers can work on projects such as building roads and bridges and installing water and sewer systems.
  3. Private businesses: Private businesses also need qualified pipelayers to help with their projects. Pipelayers can work on projects such as installing pipelines for oil and gas companies and building water and sewer systems for commercial properties.
If you are interested in a career as a pipelayer, there are a few things you can do to improve your chances of getting hired. First, get the necessary training and certification. Second, build your skills and experience. Third, network with other pipelayers and construction professionals.
Safety Tips for Pipelaying
  1. Always wear personal protective equipment (PPE), including hard hats, safety glasses, steel-toed boots, and gloves.
  2. Be aware of your surroundings and be on the lookout for hazards, such as traffic, power lines, and other workers.
  3. Never work alone.
  4. Use the right tools and equipment for the job.
  5. Follow all safety procedures and regulations.
  6. Be alert and aware of your surroundings at all times.
  7. Be aware of the weather conditions and take precautions to stay safe in extreme weather.
  8. Be prepared for emergencies and have a plan in place. Pipelaying is a dangerous job, but it can be made safer by following these simple safety tips.
In conclusion, the PL87 pipelayer is an indispensable asset for construction companies seeking efficient pipelaying solutions. With its power, versatility, and reliability, this equipment excels in laying large-diameter pipes for water, sewer, gas, and utility projects. Its user-friendly operation ensures safety and productivity, while its robust performance guarantees successful outcomes.
From its fuel-efficient Cat C15 ACERT engine to its impressive lift capacity, slope capability, and side-to-side stability, the PL87 is tailored to handle various terrains and challenging conditions. Whether it's pipeline construction, sewer and water main installation, foundation work, or other heavy civil construction projects, the PL87 pipelayer proves its worth. Take advantage of this remarkable machine to enhance your pipelaying projects.
