Articulated Dump Trucks: Types, Uses, Benefits & Buying Guide
8 Lectura mínima
Ethan Rooney
Ethan Rooney
Account Manager, Boom & Bucket
abril 18, 2023
An articulated dump truck (ADT), also called an articulated hauler, is a heavy-duty off-highway truck designed to transport large quantities of soil, rock, gravel, overburden and other materials across demanding terrain.
Unlike a conventional highway dump truck, an articulated dump truck has a front tractor unit and rear dump body connected by an articulation joint. This design helps the machine maneuver across rough, uneven and challenging haul roads.
Articulated dump trucks are commonly used in construction, mining, quarrying, road building, forestry and large-scale earthmoving. They're particularly useful when a project requires substantial hauling capacity but the jobsite includes steep grades, soft ground or poor haul-road conditions. Caterpillar describes its three-axle articulated trucks as being suited to steep grades, rough terrain and generally poor haul conditions.
If you're considering an articulated truck for your fleet, understanding its configuration, applications, capabilities and operating costs can help you choose the right machine.
What Is an Articulated Dump Truck?
An articulated dump truck is an off-highway hauling machine consisting of two primary sections:
  1. Front tractor: Contains the engine, transmission, cab and front axle.
  2. Rear dump body: Carries and unloads the material.
  3. Articulation joint: Connects the two sections and allows the machine to pivot.
The articulation joint is one of the machine's biggest advantages. Rather than relying on conventional steering alone, the machine bends at the center, helping it maneuver through challenging jobsites.
This makes articulated haulers particularly useful when terrain and maneuverability matter as much as payload capacity.
Articulated Truck vs. Semi-Truck
An important distinction: an articulated dump truck is not the same thing as a highway semi-truck or tractor-trailer.
A semi-truck is primarily designed for transporting goods on roads using a tractor and trailer. An articulated dump truck is designed primarily for off-road material hauling and uses a dump body integrated with its articulated chassis.
That distinction matters when researching or buying heavy equipment because the machines have very different applications, specifications and operating environments.
Types of Articulated Dump Trucks
Articulated haulers come in different configurations and sizes.
Standard Articulated Dump Trucks
These are the most common type for construction and earthmoving.
They're used to transport:
  1. Soil
  2. Sand
  3. Gravel
  4. Rock
  5. Fill material
  6. Overburden
  7. Construction debris
Ejector Articulated Trucks
Ejector trucks use a mechanism to push material out of the body rather than relying solely on conventional dumping.
This configuration can be useful when controlled unloading or reduced dependence on raising the dump body is important.
Bare-Chassis Articulated Trucks
Some articulated platforms can be configured for specialized applications rather than conventional material hauling.
Examples include:
  1. Water hauling
  2. Waste handling
  3. Service applications
  4. Fuel and lubricant transport
Caterpillar currently lists bare-chassis articulated trucks for specialized applications including water, waste, service, and fuel/lube transport.
What Are Articulated Dump Trucks Used For?
The right articulated truck can support a wide range of heavy-equipment applications.
Construction
Construction companies use ADTs to move soil, gravel, sand, rock and other materials around large jobsites.
They're particularly valuable for:
  1. Mass excavation
  2. Site preparation
  3. Road construction
  4. Embankment work
  5. Large-scale grading
  6. Foundation excavation
Mining
Articulated trucks can transport material in mining environments where terrain and haul-road conditions make maneuverability important.
The appropriate machine depends on factors such as haul distance, material, production requirements and site conditions.
Quarrying
Quarries can use articulated haulers to move rock, aggregate, overburden and other materials between excavation and processing areas.
Road Construction
ADT trucks can haul material for:
  1. Road bases
  2. Embankments
  3. Excavation
  4. Drainage projects
  5. Site preparation
Land Development
Large development projects often require moving substantial amounts of soil.
An articulated hauler can work alongside excavators, dozers, graders and loaders to create an efficient material-moving cycle.
Articulated Dump Truck vs. Rigid Dump Truck
Choosing between an articulated and rigid dump truck largely comes down to terrain, payload, haul-road conditions and production requirements.
Caterpillar similarly positions articulated trucks for rough terrain and poor haul conditions, while its off-highway trucks are designed to reach higher speeds on well-maintained haul roads.
In simple terms: choose an articulated truck when terrain and maneuverability are major concerns; consider a rigid truck when maximum payload and high-volume hauling on prepared roads are the priority.
Key Articulated Dump Truck Specifications
When comparing articulated haulers, don't look at payload alone.
Important specifications include:
  1. Rated payload
  2. Body capacity
  3. Operating weight
  4. Engine power
  5. Maximum speed
  6. Turning radius
  7. Ground clearance
  8. Articulation angle
  9. Dump-body configuration
  10. Tire size
  11. Drivetrain
  12. Fuel capacity
Payload varies substantially between models.
For example, Caterpillar's current articulated-truck lineup lists rated payloads from 26.5 tons for the 725 to 45.2 tons for the 745, with several models in between.
These figures demonstrate why buyers should compare individual models rather than assuming all articulated trucks have similar capacity.
Benefits of Articulated Dump Trucks
1. Excellent Rough-Terrain Performance
Articulated trucks are designed to work where conventional road trucks may struggle.
Their articulation and drivetrain configuration help them navigate challenging jobsites.
2. High Productivity
Large dump bodies allow operators to move substantial quantities of material per cycle.
The key is matching payload capacity to the loading equipment and haul distance.
3. Maneuverability
The articulated frame allows the machine to navigate changing terrain and tighter areas more effectively than many rigid trucks.
4. Versatility
ADTs can support construction, mining, quarrying, road building, forestry and earthmoving applications.
5. Traction
Many articulated haulers are designed for difficult surfaces where traction is critical.
6. Operator Technology
Modern articulated trucks can include technologies designed to simplify operation, improve productivity and support operator awareness. Features vary by manufacturer, model and configuration. Caterpillar, for example, highlights automated technology features on current articulated trucks.
How Much Does an Articulated Dump Truck Cost to Operate?
There isn't one universal operating cost for an ADT.
Your actual cost depends on:
  1. Fuel consumption
  2. Operator labor
  3. Maintenance
  4. Tires
  5. Repairs
  6. Haul distance
  7. Payload
  8. Cycle time
  9. Machine age
  10. Utilization
  11. Terrain
One of the most useful ways to evaluate hauling efficiency is cost per ton moved, rather than looking only at hourly operating cost.
A larger truck may cost more per hour but move significantly more material per cycle. The more important question is whether the machine improves the project's overall production economics.
How to Buy a Used Articulated Dump Truck
Buying used can provide substantial hauling capability without the acquisition cost of a new machine, but condition is critical.
Before purchasing a used articulated truck, inspect:
Articulation Joint
Check for excessive play, wear, cracks, damage and hydraulic leaks.
Engine and Transmission
Review maintenance records and look for signs of unusual operation or neglected maintenance.
Dump Body
Inspect the body for excessive wear, cracks, deformation and previous repairs.
Hydraulic System
Check cylinders, hoses, connections and seals for leaks or damage.
Tires
ADT tires can represent a significant replacement expense. Check tread, sidewalls and overall condition.
Frame
Look carefully for cracks, structural repairs or damage.
Hours
Operating hours provide useful context, but hours alone don't determine machine condition.
Maintenance History
A documented maintenance history can provide valuable insight into how the machine was operated and cared for.
For used equipment, condition and maintenance history can matter just as much as age.
Is an Articulated Dump Truck Right for Your Project?
An articulated truck can be an excellent choice when your project requires:
  1. Off-road hauling
  2. High material volume
  3. Rough-terrain mobility
  4. Frequent movement between loading and dumping areas
  5. Strong traction
  6. Flexible maneuverability
However, it may not be the most economical choice for every project.
Before buying, consider:
  1. How much material needs to be moved?
  2. What is the average haul distance?
  3. How difficult is the terrain?
  4. What is the condition of the haul road?
  5. What payload does the project require?
  6. What loader or excavator will load the truck?
  7. How many trucks are needed to maintain production?
  8. What are the expected fuel, tire and maintenance costs?
The best truck is the one that fits the entire production cycle, not simply the one with the biggest payload.
Frequently Asked Questions
What is an articulated dump truck?
An articulated dump truck is an off-highway hauling machine with a front tractor and rear dump body connected by an articulation joint. It is designed to move material across rough and challenging terrain.
What is an articulated truck used for?
Articulated trucks are commonly used for construction, mining, quarrying, road building, land development and other large-scale earthmoving applications.
What is the difference between an articulated and rigid dump truck?
An articulated dump truck pivots at the center, providing excellent maneuverability on rough terrain. A rigid dump truck has a fixed frame and is generally better suited to high-volume hauling on well-maintained roads.
How much can an articulated dump truck carry?
Payload depends on the specific model and configuration. Current Caterpillar articulated trucks, for example, range from 26.5 to 45.2 tons of rated payload across its listed models.
Are articulated dump trucks good for mining?
They can be, particularly when difficult terrain and haul-road conditions make maneuverability important. The appropriate machine depends on the mine, material, haul distance and production requirements.
Are used articulated dump trucks worth buying?
They can be an excellent option when the machine has been properly maintained and inspected. Buyers should pay particular attention to the articulation joint, drivetrain, hydraulics, tires, frame, dump body and maintenance history.
Find the Right Used Articulated Truck
An articulated dump truck can be a powerful addition to a construction, quarrying, mining or earthmoving fleet—but the right machine depends on your application, terrain, payload requirements and operating costs.
Need help choosing?
Start by comparing your project requirements with available machine specifications.
→ Explore Heavy Equipment Buying Guides
Ready to Compare Machines?
Browse Boom & Bucket's selection of used articulated trucks and compare machines by model, hours, specifications, condition and price.
→ Browse Used Articulated Trucks
Building a Complete Fleet?
An articulated truck rarely works alone. Pair your hauler with the right excavator, wheel loader, bulldozer or other heavy equipment to create an efficient material-moving operation.
→ Explore Used Heavy Equipment
Ethan Rooney
Ethan Rooney is an Account Manager at Boom & Bucket, helping clients buy and sell heavy equipment with confidence through a transparent, tech-driven marketplace. A U.S. Army Military Police veteran, Ethan brings over a decade of customer-facing experience across automotive sales and finance, known for building strong relationships and delivering results through trust and service.
