The Best Hard Hats for Construction
julio 1, 2022
PPE doesn't get tons more crucial than your trusty, rugged hat.
After all, these crucial protection items guard your head! And that, in turn, means your mind (i., E. The most essential organ for your body) is less likely to suffer in a twist of fate. That's why we recommend spending more greenbacks to get a great one!
Are you seeking out the first-rate tricky hats for production?
Well, you are within the proper area. Keep reading for a complete guide to choosing remarkable hard hats.
Qualities of an Awesome Hard Hat
The struggle to shop for the pleasant, rugged hat for construction is received or lost on understanding what brands to look for! Here are a few key factors to keep in mind that must help you find the right one for your desires:
Type
In preferred, there are 2 principal sorts of hard hats you may need:
  1. Type 1 hats protect you if something falls from a height onto your head. It'll reduce the impact of the blow and, with any luck, prevent serious injury.
  2. Type 2 hats do that but also protect you from lateral impacts (i.e., from the front, back, or sides).
Think about the jobs/sites you'll be working on. If moving equipment, general workers, or materials are in transit, you need a type 2 hard hat. However, check the current legal standards in your area. It's the best way to ensure you buy a hard hat that complies with the rules.
Class
A hard hat's "Class" pertains to electrical protection. These days, there are 3 Class labels, each with its own brand and electrical rating:
  1. Class E hats are "electrical, non-conductive." They reduce the impact of touching higher-voltage conductors (tested at 20,000 volts).
  2. Class G hats are "general, non-conductive." They reduce the impact of touching low-voltage conductors (tested at 2,200 volts).
  3. Class C hats are "conductive, no electrical rating." They are not designed to protect you from electrical hazards.
Once again, think about what you do and where you'll work. Electrical workers are more risky, so they'd need a Class E hard hat. A Class G may suffice for a general construction worker.
Comfort, Adjustability, and Materials
Hard hats that are too big, small, and heavy aren't fun. So, make sure you choose one that:
  1. It is inherently comfortable (the more points of suspension, the better!)
  2. You can adjust it to fit your head size, and
  3. It is made from lightweight materials (e.g., carbon fiber).
It's helpful to have accessory slots available as well. They provide newfound versatility for safety helmets, allowing you to attach face and hearing protection. On that note, a "reverse donning arrow" indicates they can be worn forward or backward.
Style
Okay, so practicality always trumps aesthetics on the scale of material importance. But -- and it's a big but -- you want your hard hat(s) to look good too. If it doesn't, you (or your workforce) are much less likely to wear them!
For example, the only industry consensus is that full-brimmed hard hats look better (and more professional) than cap-style ones, although they limit the attachments you can use.
Oh, and if you work outside, you'll want light-colored hats over dark ones, which are notorious for getting too hot. A safe helmet color to choose from is yellow, ubiquitous among construction workers. Finally, why not go full Top Gun and let people customize their helmets with stickers?
Are you looking for great examples of hard hats that tick the boxes above? Here are 2 of them:
Pyramex Ridgeline Full Brim
This full-brim hard hat from Pyramex is a great all-rounder that balances its price and affordability with practicality. It's a Type 1 hat with class C, G, and E ratings. Made from ABS plastic, it is able to be utilized in excessive and occasional temperatures.
The Ridgeline has a four-point suspension gadget, can be adjusted, and has a head pad for additonal comfort.
Acerpal OSHA Full Brim
This durable and hardwearing product from Acerpal is hard to fault. It's another Type 1 hat with a full brim that provides impressive defense against falling debris and rain. Like the Pyramex, it also offers Class C, G, and E protection and is suitable for high and low temperatures.
For comfort, the Acerpal has soft brow padding and a head pad. It is available in various sizes, all with a 4-point suspension system that can be upgraded to 6-points (for a fee!). You also have a whopping 28 graphics and color schemes to choose from.
Here's a table summarizing the information on the best hard hats for construction based on the provided article:
These hard hats are chosen based on their type, class, and features, providing comprehensive protection and comfort for construction workers.
Time to Choose Your Hard Hat!
Do you need help to choose the right hard hats for construction? We hope the insights and suggestions in this article will help. Remember them; it shouldn't be long before you and your team have adequate head protection.
Want to buy used construction equipment that you can trust? Click here to find out how we can help.
