The Best Knee Pads for Construction
julio 3, 2022
Any construction worker will agree that the job can be pretty brutal on their body --- and it's not just about the heavy lifting either. You spend a lot of time kneeling on every surface from soil and plywood to concrete, often resulting in discomfort, swelling, and over the years this can have a significant impact on how easily you get around with age.
With that in mind, buying a pair of the best knee pads for construction might be a good idea. And that's why we'll give you a quick overview of our best picks among construction knee pads right here!
ProKnee AP16 Knee Pads
If you don't mind paying over $100 for your knee pads, you'll find that most construction workers agree on the ProKnee knee pads being the absolute best model you can get. They're a game-changer because the long, broad pads keep you stable without putting any actual pressure on your knees.
When you take a look at their design, you'll notice that they're more like shin pads than knee pads thanks to their length --- however, that's what allows them to transfer the weight distribution across your whole leg, resulting in zero knee pressure. If you have any bad ligaments or other knee or back injuries, these are the only knee pads that probably won't cause you any major pain.
And once you get them adjusted just right, you won't experience any chafing either. Sure, they're a bit clunky when you walk around in them, but they make working on the ground a pleasure. Also, they're custom-sized and have plenty of replaceable parts.
Troxell USA Supersoft Leatherhead Knee Pads
If you're looking for some of the best knee pads for construction made in the US, this model from Troxell is a popular choice among construction workers. And the main reason for that is their comfortable, unrestricted design.
They've got an incredibly tough neoprene padding, with a cover of durable, thick leather --- meaning they're as durable as possible on the outside, while still being soft and comfy on the inside. They're the combo of practical protection and comfort that you're looking for.
Plus, the hook and loop closure makes it quick and easy to put on and remove, without any buckles or clasps that would degrade and break over time. If you're not fond of cumbersome, bulky knee pads but still want a similar degree of protection, Troxell is a fine choice. Also, they're not overly expensive at around $50.
NoCry Professional Knee Pads
Here's a product that lives up to its name, especially if you're looking for something more than the average level of protection from your knee pads. These NoCry Professional knee pads have an extremely comfortable soft gel inner core, which is further enhanced with EVA foam padding. And the exterior comes in the form of a thick poly shield with a non-slip tread --- practically the most heavy-duty protection you can get without sacrificing comfort too much.
Also, you may have heard about some issues with subpar rivets on some of their earliest models --- these have since been resolved, and defects have been replaced by the company free of charge. And at $25, they're practically a bargain.
Foam Knee Pads: Protecting Your Knees with Comfort
Knee pads have become an indispensable accessory for those who work in trades that require frequent kneeling. Whether you're in construction, flooring, or any profession where you find yourself on your knees for extended periods, wearing knee pads can make a significant difference in your comfort and safety. Within the realm of knee pads, foam knee pads stand out for their comfort and protection, thanks to their foam padding and ergonomic design.
Understanding Foam Knee Pads
Foam knee pads are designed to provide excellent protection to your knees while ensuring a snug fit and optimal comfort. The foam padding inside these knee pads is the secret behind their success. The foam padding is often made of EVA foam, which is known for its lightweight and shock-absorbing properties. This foam absorbs the impact, preventing your knees from bearing the brunt of the force when you kneel on hard surfaces.
Key Features of Foam Knee Pads
Foam Padding: As the name suggests, the foam padding is the highlight of these knee pads. This foam is gentle on your knees, making it possible to work comfortably for long hours.
Ergonomic Design: Foam knee pads are often crafted with an ergonomic design that contours to the shape of your knees. This design ensures that the knee pads fit snugly and securely, preventing them from slipping out of place during work.
Two-Strap Design: Many foam knee pads feature a two-strap design with elastic straps and hook and loop straps. This design allows you to adjust the knee pads to your desired fit, ensuring they stay in place comfortably.
Soft Gel Core: Some foam knee pads have a soft gel core integrated into the foam padding. This core adds an extra layer of cushioning and support, enhancing the protection for your knees.
Choosing the Right Foam Knee Pads
When it comes to choosing foam knee pads, several factors should influence your decision:
Work Environment: Consider the nature of your work. Are you primarily working on hard surfaces or soft surfaces? This will help you determine the level of protection your knees need.
Comfort: Look for knee pads that offer a comfortable fit. The foam padding and ergonomic design play a significant role in ensuring that the knee pads feel comfortable even during long hours of work.
Strap System: Evaluate the strap system of the knee pads. Elastic straps and hook and loop straps provide an adjustable and secure fit. Slip buckle clips and buckle closures are also options to explore.
Additional Features: Some foam knee pads come with features like thigh support or a top strap for added security. Consider these features based on your specific requirements.
The Importance of Foam Knee Pads
In the world of construction work and similar professions, protecting your knees is of paramount importance. Kneeling on hard surfaces for extended periods can lead to discomfort and, over time, potential knee injuries. Foam knee pads provide an excellent solution by offering both protection and comfort, allowing you to work with confidence.
Foam knee pads are a valuable addition to any worker's gear, especially those who spend long hours on their knees. The combination of foam padding, ergonomic design, and secure straps ensures a snug fit and excellent protection for your knees. By choosing the right foam knee pads for your specific needs, you can work comfortably and safeguard your knees from the strains of your profession.
Make sure you have the equipment you need for the work you're doing. Safety gear can go a long way towards making the work less troublesome and the weekends more enjoyable.
