10 Common Skid Steer Issues: A Quick Guide
March 27, 2023
Skid steers are essential tools for many businesses and construction job sites. They are powerful and versatile machines that can help you move dirt, gravel, and other materials quickly and efficiently. But like any machine, they can experience problems from time to time. Here are 10 common issues and how to fix them.
undefined
1. Skid Steer Won't Start
One of the most frustrating issues with skid steers is when they won't start. If your skid steer won't start, there are a few things you can check:
  1. Check the battery: Make sure the battery is charged and has the correct voltage.
  2. Check the starter: Make sure the starter is working correctly and that there are no loose connections.
  3. Check the fuel system: Check the fuel level and ensure there are no clogs in the fuel system.
undefined
2. Skid Steer Overheating
Overheating is another common issue with skid steers, especially during hot summer months. Overheating can cause significant damage to the engine, so it's crucial to address the issue as soon as possible. Here are some things you can do to fix an overheating skid steer:
  1. Check the coolant level: Make sure the coolant level is adequate.
  2. Check the radiator: Ensure that the radiator is clean and free of debris.
  3. Check the thermostat: If the thermostat is not working correctly, it may be causing the engine to overheat.
undefined
3. Skid Steer Hydraulic Issues
Hydraulic issues are common with skid steers, and they can affect the machine's performance. If you notice that your skid steer is having hydraulic issues, here are some things you can do to fix them:
  1. Check the hydraulic fluid level: Make sure the hydraulic fluid level is adequate.
  2. Check the hydraulic filter: Ensure that the hydraulic filter is clean and free of debris.
  3. Check the hydraulic hoses: Check for leaks or any signs of damage on the hydraulic hoses.
undefined
4. Skid Steer Engine Issues
The engine is the heart of the skid steer, and engine issues can significantly impact the machine's performance. If you notice any engine issues with your skid steer, here are the details and some things you can do:
  1. Check the air filter: Make sure the air filter is clean and free of debris.
  2. Check the fuel filter: Ensure that the fuel filter is clean and free of debris.
  3. Check the spark plugs: If the spark plugs are dirty or worn out, they may need to be replaced.
undefined
5. Skid Steer Electrical Issues
Electrical issues are not uncommon with skid steers, and they can cause significant problems if left unaddressed. If you notice any electrical issues with your skid steer, here are some things you can do to fix them:
  1. Check the battery: Ensure that the battery is charged and the power on has the correct voltage.
  2. Check the wiring: Look for any signs of frayed or damaged wiring.
  3. Check the fuses: If a fuse has blown, it may be causing the electrical issue.
undefined
6. Skid Steer Tire Issues
Tire issues are common with skid steers, and they can affect the machine's traction, power and stability. If you notice any tire issues with your skid steer, here are the details and some things you can do:
  1. Check the tire pressure: Ensure that the tire pressure is at the correct level.
  2. Check the tread: Look for any signs of damage or uneven wear.
  3. Check the alignment: If the alignment is off, it can cause uneven
undefined
7. Skid Steer Bucket Issues
The bucket is one of the most critical components of a skid steer loader. Bucket issues can cause significant problems in the machine's performance, affecting the loading process and unloading process. Here are some things you can do to fix bucket issues:
  2. Check the bucket cylinders: If the bucket cylinders are not working correctly, they may need to be replaced.
  3. Check the pins and bushings: If the pins and bushings are worn out, they may need to be replaced.
undefined
8. Skid Steer Belt Issues
Belt issues are common with skid steers, and they can affect the machine's performance. If you notice any belt issues with your own skid steer loader, here are some things you can do to fix them:
  1. Check the belt tension: Make sure the belt tension is correct.
  2. Check the belt for wear and tear: If the belt is worn out, it may need to be replaced.
  3. Check the pulleys: Ensure that the pulleys are aligned correctly and not worn out.
undefined
9. Skid Steer Fuel Issues
Fuel issues can cause significant problems in the skid steer's performance. If you notice any fuel issues with your skid steer, here are some things you can do:
  1. Check the fuel level: Ensure that the fuel level is adequate.
  2. Check the fuel filter: If the fuel filter is dirty, it may need to be replaced.
  3. Check the fuel pump: If the fuel pump is not working correctly, it may need to be replaced.
undefined
10. Skid Steer Loader Chain Issues
Chain issues are common with skid steers, and they can cause significant problems in the machine's performance. Here are some things you can do to fix chain issues with skid steer loaders:
  1. Check the chain tension: Make sure the chain tension is correct.
  2. Check the chain for wear and tear: If the chain is worn out, it may need to be replaced.
  3. Check the sprockets: Ensure that the sprockets are aligned correctly and not worn out.
undefined
Final Note: Skid Steer Loaders
Skid Steer Operating Weight
Operating weight is a crucial factor to consider when it comes to skid steers. It refers to the weight of the machine and attachments. The operating weight can affect the stability and maneuverability of the skid steer, especially on uneven terrain. It's important to keep in mind the operating weight of your skid steer. This can affect the transportation of the machine and limit of the roads.
Skid Steer Operating Capacity
Operating capacity is another essential factor to consider when it comes to skid steers. It refers to the amount of weight that the machine can safely carry. The operating capacity can vary depending on the skid steer's position, attachments, and the terrain it's operating on. It's crucial to determine the operating capacity of your skid steer to ensure that you do not exceed the weight limit and cause damage to the machine.
