Exploring Different Types of Pavers Used in Construction
10 Min read
January 20, 2024
Pavers play a crucial role in the construction industry, providing a durable and reliable solution for creating smooth and sturdy surfaces in various applications. There are some notable players in the industry renowned for their commitment to durability, reliability, and productivity.
The LeeBoy 8500C series, Weiler P385A, Dynapac SD2550CS etc. stand out for their exceptional features, making it an ideal choice for commercial and mainline paving applications.
Key Features of LeeBoy 8500C Series
The LeeBoy 8500C series pavers are designed to meet the demanding requirements of modern construction projects. One of the standout features is the LeeBoy Legend Electric Screed system, which gives contractors the flexibility to choose between propane-fired or economical, efficient electric heating systems. This adaptability ensures that contractors can select the most suitable option based on their project needs and budget constraints.
Specifications of LeeBoy 8500C
The LeeBoy 8500C series boasts key specifications that contribute to its superior performance on construction sites:
Basic Paving Width: The paver offers a versatile paving width range of 8 to 15 feet (2.44 to 4.57 meters). This flexibility allows contractors to adapt to different project requirements, ensuring precision and efficiency in various paving applications.
Paving Speed: The LeeBoy 8500C series features an impressive paving speed ranging from 0 to 160 feet per minute (48.8 meters per minute). This high-speed capability enhances productivity, enabling contractors to complete projects promptly without compromising on quality.
Weight: Weighing in at 17,800 pounds (8,074 kilograms), the LeeBoy 8500C strikes a balance between durability and maneuverability. The optimal weight ensures stability during operation while allowing for easy transportation between job sites.
Power Rating: Equipped with a Tier 4i engine, the LeeBoy 8500C series delivers a power-packed performance with an 85 horsepower (63 kW) rating at 2,600 rpm. This ensures that the paver can handle the demands of diverse paving applications with efficiency and reliability.
Benefits of LeeBoy 8500C Series Pavers
Durability: The LeeBoy 8500C series is built to withstand the rigours of heavy-duty construction work. Its robust construction and high-quality materials ensure durability, providing contractors with a reliable solution for long-term use.
Reliability: The reliability of LeeBoy 8500C pavers stems from the brand's commitment to engineering excellence. Contractors can trust these pavers to deliver consistent and dependable performance, reducing downtime and enhancing overall project efficiency.
Productivity: The combination of versatile features, such as adjustable paving width and high-speed capabilities, makes the LeeBoy 8500C series highly productive. Contractors can efficiently complete paving projects, contributing to increased overall productivity on the job site.
Weiler P385A
Next introducing the P385A, a second-generation commercial-class paver that combines proven designs with innovative features. Let's delve into the key benefits and features of the Weiler P385A that set it apart in the competitive landscape of construction pavers.
Proven Designs and Hydraulic Efficiencies
The Weiler P385A boasts a range of features that contribute to its superior performance. One notable element is the pressure-compensated hydraulic pump, which enhances hydraulic efficiencies. This design ensures optimal power distribution, resulting in smoother operation and increased overall efficiency on the construction site.
Additionally, the paver is equipped with raised cut-off doors providing a remarkable 127 mm (5 inches) of ground clearance. This feature is essential for navigating uneven terrain and ensures that the paver maintains stability during operation, even in challenging conditions.
Optimal Material Delivery Management
Efficient material delivery is critical for a successful paving operation. The Weiler P385A addresses this with a standard conveyor paddle sensor, which optimizes material delivery management. This sensor ensures a consistent and uniform flow of materials, contributing to the precision of the paving process.
Fuel Efficiency and Reduced Noise
The Weiler P385A stands out for its commitment to sustainability and cost-effectiveness. The variable-speed hydraulic fan not only reduces noise levels but also plays a crucial role in minimizing fuel consumption. This feature enhances the overall environmental friendliness of the paver, aligning with the industry's growing emphasis on eco-friendly construction practices.
Hydraulic-Driven Generator for Longevity
To further optimize fuel consumption and increase the longevity of the generator, the Weiler P385A incorporates a hydraulic-driven generator that operates at low engine idle. This innovative design ensures that the generator operates efficiently while consuming less fuel, contributing to lower operating costs and extended equipment life.
Exceptional Visibility and Control
The Weiler P385A prioritizes operator visibility and control with three different operating positions—top, mid-level, and screed. These positions are strategically designed to optimize visibility and accommodate crew requirements, allowing operators to work comfortably and with precision.
Moreover, individual cut-off doors prevent spillage and limit cleanup efforts. These doors can be set to automatically close when reversing direction, reducing the likelihood of material wastage and streamlining the overall paving process. The electronic controller keeps the operator informed of machine operating conditions, ensuring a smooth and informed operation.
Minimize Cleanup and Maximize Paving Capability
The Weiler P385A's design focuses on minimizing cleanup efforts and maximizing paving capability. Independent control of each side of the delivery system enables variable-width paving, offering flexibility in adapting to diverse project requirements. The cut-off doors enable a narrow paving range of 0 - 1.1 meters (0 - 3 feet 10 inches), catering to projects with specific width constraints.
Dynapac SD2550CS
The Dynapac SD2550CS Paver is a cutting-edge construction machine equipped with features that not only enhance performance but also prioritize fuel efficiency and environmental compliance. This paver, boasting an array of innovative specifications, stands as a testament to Dynapac's commitment to delivering state-of-the-art equipment for the construction industry.
Eco Mode for Significant Fuel Savings
One standout feature of the Dynapac SD2550CS is the Eco Mode, a function designed to achieve substantial fuel savings. By implementing this mode, operators can optimize fuel consumption, contributing to both cost savings and environmental sustainability. The Eco Mode is a testament to Dynapac's dedication to incorporating eco-friendly solutions into their machinery.
Stage V / Tier 4f Compliance
The Dynapac SD2550CS is equipped with a Stage V / Tier 4f engine, ensuring compliance with the latest emission standards. This not only aligns with stringent environmental regulations but also translates into significant fuel cost savings. Dynapac products with Stage V engines exemplify the company's commitment to delivering environmentally conscious solutions without compromising on performance.
Masses and Traction
The paver weighs 22.5 tons, providing a stable and robust foundation for paving operations. With a maximum paving speed of 28 meters per minute and a transport speed of 4.0 kilometres per hour, the Dynapac SD2550CS ensures efficient movement and precise placement of materials during construction projects.
Engine and Drive Specifications
The heart of the Dynapac SD2550CS is the Cummins QSB6.7-C260 engine. With emissions meeting EU Stage IIIA standards, this engine not only delivers powerful performance but also adheres to stringent environmental requirements. The rated power, as per SAE J1995, is an impressive 194 kW at 2200 rpm, ensuring the paver's capability to handle diverse paving tasks.
The electrical system operates at 24 volts, providing the necessary power for the paver's various components. The fuel tank, with a capacity of 337 litres, allows for extended operation without frequent refuelling, contributing to the uninterrupted workflow on construction sites.
Paving Capabilities
The Dynapac SD2550CS offers versatility in paving with a basic width of 2.55 meters and a maximum paving width of 14 meters. It can accommodate various project requirements, providing flexibility in paving tasks. The maximum layer thickness is 360 millimetres, and the theoretical placement capacity is an impressive 1100 tons per hour, showcasing the paver's efficiency in handling substantial workloads.
Caterpillar AP655
The AP655 asphalt paver stands as a pinnacle of innovation, offering a robust rubber track design that not only ensures optimal performance but also guarantees a substantial return on investment. This high-production paver boasts a range of features, including a rapid heating screed system, durable components, and user-friendly technology, all while demonstrating exceptional fuel efficiency.
With various screed options, the AP655 excels in delivering versatility and high-quality results across a spectrum of projects, including interstates, highways, airports, and parking lots. Let's delve into the features that make the AP655 a standout choice in the asphalt paving landscape.
Integrated 70 kW Generator
An exclusive feature of the AP655 is its integrated 70 kW generator, designed for fast and reliable screed heating. Developed by the same team that engineered the renowned D7E electric drive dozer, this generator ensures efficient and consistent screed heating, significantly reducing downtime. The emphasis on durability is evident, as the generator is engineered for long operational life, reflecting the high standards set by its dozer counterpart.
Rapid Heating Screed System
The AP655's fast heating screed system is a game-changer in terms of daily production. With an impressive heating time of as little as 15 minutes, this paver allows for quicker project initiation and completion. The rapid heating capability enhances overall efficiency, contributing to a higher daily production rate.
Undercarriage Design
Designed for exceptional traction, good flotation, and swift travel, the undercarriage of the AP655 plays a pivotal role in boosting production rates. This innovative design ensures that the paver can navigate various terrains with ease, contributing to increased efficiency on the job site.
Exclusive Airflow Design
The AP655 prioritizes the well-being of the operating crew and the durability of its components with an exclusive airflow design. This feature improves operating conditions for the crew, ensuring a comfortable working environment. Simultaneously, it keeps critical components cooler, enhancing their longevity and durability, even under demanding operational conditions.
Conclusion:
In short, the evolution of construction pavers has brought forth a range of cutting-edge models, each excelling in unique ways. From the LeeBoy 8500C series' adaptability to the Weiler P385A's proven designs, the Dynapac SD2550CS's environmental consciousness, to the AP655's integration of advanced technologies, these pavers redefine efficiency in construction. As the industry continues to advance, these versatile machines showcase a commitment to durability, reliability, and productivity, meeting the diverse needs of modern construction projects with precision and innovation.
